Battery Pack becomes slightly out of balance overnight?
Discussion in 'Roadster: Technical' started by sethr, Aug 7, 2015.
  1. sethr
    sethr CPO Roadster #1089
    Fairfax, VA
    Hi all: I wonder if anyone can shed light on what I have noticed recently (I've never checked this before the last couple of days). After a Standard charge at the end of the day, my pack balances in a short time, usually in about 10 - 15 minutes. But recently, when I was checking on the pack temperature in the morning, I saw that the balancing grid had a few "1's". It rebalanced in minutes (I assume because I had woken the Roadster up: the pump had not been on), but I'm wondering if this is normal, or the beginning of a problem? TIA!
  2. spaceballs
    spaceballs Member
    Sammamish
    That is normal.
  3. BartJ
    BartJ early member
    Belgium
    Personally I have never seen any 1's in the balancing grid at all
  4. djp
    djp Model 3 Performance
    Toronto, Canada
    You need to catch them during a balancing cycle, directly after completing a Standard or Range charge. They're cleared out when you start the car.
  5. hcsharp
    hcsharp Active Member
    Vermont
    I've never seen my car "re-balance" after it finishes balancing. Maybe I've missed it. If you top-off the charge it will enter a balancing stage afterwards. But I've never seen it start balancing just because it woke up.
  6. ML Auto
    ML Auto Member
    SW Florida
    Check the min and max brick voltages. Balancing will start after a few minutes after the key is turned off (or when you awaken it) when the SOC is 79% or greater, and the difference between the high and low voltages is >.02V. Balancing only occurs while awake. If your pack is out of balance, you can turn on the hazard flashers to keep the car awake until the pack is balanced. A few "1's" are good. If you see 98, then you have a problem.
