acarney
Do they just dump them in the garbage?That’s not how any of it works....at Tesla or in mass manufacturing....
Hmmm. Pretty categorical assertion. What are your credentials to say this? From my experience, it is not unusual to do QA tests along the line, pull failed parts, and then triage them separately... especially when the production item is worth >$10k.That’s not how any of it works....at Tesla or in mass manufacturing....
@acarney said “might”. Up til that, he was accurate WRT standard practices. After that, he was conjecture like everyone else At least he’s said “might” unlike those who profess to know for sure.A module isn't worth >$10k. And sure they are probably pulled off the line and re-worked, but that doesn't cause them to be classified as reconditioned. They are still new and just put back into the line with the rest of the parts.
Qualifications mentioned in this post: First charge!!unlike those who profess to know for sure.
Ok, so 90% of what he said was correct or plausible. Your only issue was the assertion that they might reclassify? I’ll agree with that.There are dozens of tests performed on the various components and module as it runs through the production system, and eventually when it’s turned into a pack. If there are issues found, the issue is dealt with, whether that involves removing it from the line for a more thorough check, or correcting on the spot. Doing so doesn’t reclassify the item as reconditioned. No one in manufacturing does that.
And it is interesting how a guy who works at Tesla can say “nobody in manufacturing does that”.Items don’t get pulled off the line and reclassified as reconditioned, and they don’t get new serial numbers after repairs. That would be a data nightmare, a huge traceability issue, and down right stupid.
It’s always funny how many people assume that they know what happens in Tesla factories, even if they have some prior manufacturing experience....
Then I suspect a high likelihood of a new pack going into the car. I just can’t imagine there are that many trashed model 3’s right now with battery packs is such a safe configuration that Tesla feels ok keeping them in service with supercharging.
This would be especially true given your low mileage. Car is written off because of strictly body damage but has 16k miles on the pack? Probably not going in yours as a “like for like or better” pack...
Reman pack is more likely. Reman doesn’t mean it came out of a crashed car.
Where the heck are these packs coming from? None of these cars are reaching end of life yet. Unless packs are being pulled off the line for original manufacturing defects that can be later corrected (which you claim wouldn’t happen, they would be corrected on the spot and used as new) where does Tesla get packs from to remanufacture? I would hope the failure rate from cars was extraordinary low... otherwise Tesla has a serious problem on warranty costs.Reman pack is more likely. Reman doesn’t mean it came out of a crashed car.
I actually would have thought the opposite. If it fails a QA test somewhere and the serial number is flagged as bad, there would have to be really strong traceability that it was inspected, repaired, and QA tested again with passing results before ultimately going back off for assembly. If it got by without any step happening and placed in a car, you now run the potential of delivering a defective product to a customer that may fail prematurely and most likely cost Tesla more when factoring in logistics and service time and potential risk to the brand image.
You flag it as bad and remove that serial number from the useable ones and if it finds its way to assembly there should be major red flags not to use it. If it fully gets inspected and reconditioned then you issue it a new serial number that has a “clean pedigree” and there is no question about if all the proper steps to repair it took place.
Based on how Tesla seems mismanaged at times and lacking communication, I would think you would want CLEAR indications to keep the bad packs segregated from any chance of making their way to final assembly.
I’m also assuming their fail rate is fairly low, I wouldn’t think they would have like a couple out of every hundred requiring intervention by a technician to correct issues. That’s why I figured it would be faster to reject it from the line and not slow down the production. Possibly if this is routine where a few packs out of every 100 need some amount of adjustments different then perfectly good ones they would have integrated on the spot repair but I would think “bin it” and then let someone else deal with it would be the cheapest, fastest, and most efficient way when working in large volumes.
I have to say that I felt the Tesla Model 3 was one of my best purchases for as long as I can remember. However, these error messages began to prompt less than 15,000 miles:
and suddenly, the car wouldn't budge (doesn't shift over to 'Drive' or 'Neutral').. Tesla ran some diagnostics and said I needed a new battery pack. I didn't mind much since I'm under warranty, but when I asked when they can replace with a new battery -- they clarified they'd be providing a "reconditioned" one... Usually, I know the Refurbs try to match similarly aged batteries, but I consider my car nearly brand new. It's unnerving because these reconditioned batteries are never as good as new batteries, and I hear complaints about folks experiencing higher maintenance costs with the never-ending charge issues stories.
- Electrical system power reduced: Vehicle may shut down unexpectedly
- Vehicle may not restart: Service is required
On Tesla's warranty coverage, they state the following: (1) ... the replacement Battery will be in a condition appropriate to the age and mileage of the vehicle sufficient to achieve or exceed the minimum battery capacity for the remainder of the warranty period of the Original Battery.; (2) If your Battery or Drive Unit requires warranty repair, Tesla will repair the unit, or replace it with a new, reconditioned or remanufactured part at the sole discretion of Tesla.
With that, I've asked Tesla if it's within their discretion, to replace the battery pack with a new one. I haven't heard a response back yet on this... but in the meantime, I'd appreciate if I can get some inputs/advice here. Thx in advance.
