Battery Pre-conditioning question
aahann
2020 MY LR AWD
Jun 19, 2020
19
15
Massachusetts
You can preheating the battery by cold weather by warming-up your interior before starting a trip. As you can see on the picture (the red icon on the right, shows that the battery preheating has been started (outside temperature was below 0° celsius).
I’m getting the impression that turning on climate before departure warms the cabin but also indirectly warms the battery because it draws current from the charging source to run the heating - not because it’s blowing hot air on the battery !! Two birds, one stone.
PatrickCH4313
568
347
Argovie, Switzerland
This is correct. And beside this, the regen is greater when starting driving at low temperature.
pt19713
701
845
Delaware
Sort of.
The front and rear Stator motors are generating heat, approximately 3.5 kW/each. The coolant picks up the heat via conduction and the coolant is pumped through the battery pack. The Stator motors can get up to ~ 200F max, about 190F in 10 minutes.
If you're not plugged in, the car will need about 7.75 kW to heat up the Stator motors, run the heat, and a few other items that draw energy. If you're plugged in with a HPWC, the 11 kW will be sufficient to power the system. If you have a 40A power source, the 9.6 kW will be sufficient. If you have a 32A source, the 7.6 kW might be able to power it but it may draw from the battery. Anything less than 32A will draw from the battery.
