Battery Replacement Option
Discussion in 'Model S: Ordering, Production, Delivery' started by irvineboy, Dec 12, 2016.
  1. irvineboy
    irvineboy Member
    Irvine, CA
    I have a neighbor who purchased a base model S. He told me there will eventually be a battery replacement option so he could technically upgrade his 70 to a 90D or P by switching out the battery. I have never heard of this. Anyone know if it is true?
  2. wesley888
    wesley888 Member
    Huntington Station, NY
    I've never seen any news regarding battery upgrade. I know for sure you can't switch to a P model since the motors and the wire are different as well. You can't just switch it out.
  3. Boourns
    Boourns Member
    Dallas
    Elon has indicated that battery upgrade would be possible in the distant future, but there are no specific plans revealed that I know of. Also, to go from a non-P to a P would also require swapping out the rear motor and other components.
  4. Kenx008
    Kenx008 Member
    Minnesota
    Your neighbor may be mistaken for being able to upgrade a 60 to 75. The 70 and 90 have different motors so a simple battery replacement won't get you the same performance.
  5. brkaus
    brkaus Active Member
    It has been mentioned as future possibility. It was also mentioned that it wouldn't be financially reasonable to upgrade in "small steps". It would be too expensive to upgrade annually. I think the price was $20k to upgrade a 60->90 and you had to turn in the old battery.
  6. GregKo
    GregKo Member
    New Jersey
    It was $20K to go from P90DL to P100D. I got the email from Tesla. P90D without the L was not sent the letter...
    Greg
  7. smilepak
    smilepak Active Member
    Eastvale, CA
    I wonder if this holds true. If it is might worth keep my lease than buy a cpo 85d
  8. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    Your neighbor may "eventually" be correct but Tesla has not made any such statement. So as of now, it is not true.
    I am confident that Tesla will never offer its customers the ability to change a non-Performance model to a Performance model, or change a single motor Tesla to a Dual Motor. But someday it may be possible to buy a new replacement battery that has more capacity than the battery that the car was first sold with.
  9. tpham07
    tpham07 Member
    Baton Rouge
    Changing a single motor to a dual motor would require both motors to be swapped since aren't dual motor vehicles two smaller motors vs one big motor in the regular RWD version?
