I dislike the idea of a "hidden reserve." Of course, some people set their clocks 5 minutes fast, which they seem to believe keeps them from being late. I've not been that good with self-deception.
Vbsdan- Do you have the current software update running? I thought that 'Tesla' changed the range showing and calcs so it starts at a 265mi for full charge vs 300mi which is 'realistic' at 55 mi w/ good conditions.
My head's starting to hurt thinking about this, so maybe one of you can help. If you do a "range" charge using a 14-50NEMA, you'd have 85kWh/265 miles. My question is can I make it 250 miles if I go low and slow?
Second part to the question is how long would it take to do the about charge if you started with about 40 miles remaining.
With a standard mode charge, our "Rated" range is 241 miles, although our projected consistently falls pretty far short of that, usually by around 60 miles with conservative driving. This makes us a bit nervous for our planned trip to AZ (from LA) with the car in November, but that's a discussion for another thread that I'll be making shortly. We never worry for our daily driving, but we are definitely suffering pre-roadtrip range anxiety, though, especially since there are no superchargers (and none planned!!!) for the 10 heading east. We're hoping as we adapt to the car and as the batteries are put through a few cycles that our projected range will improve.
Took another long drive today and got home with 10 miles of range remaining. Went out to dinner and back and I was down to 2 miles. The parking lot behind my building was empty so it seemed like a good time to see what happens when you get down to zero. I cranked the heater up to high and drove around the lot. BTW Tesla is right about the heater using way more juice than the seat heaters. Both seat heaters and rear defrost barely moved the Kw needle but the cabin heater sure did. Anyway I circled the lot until I got to zero and at that point the range indicator in the speedo changed from "1" to "Charge Now". I took a few more laps around the (small) parking lot, nothing else happened. Since I'm pretty sure that running it below zero is not a good thing that's as far as I went. The display was showing 76.9 kWh used, and that was from a full range charge. The battery indicator (which turned red at 5 miles remaining) still shows something left but I'm not going to speculate about its meaning. Maybe you can drive 1/2 mile after you hit zero, maybe 5, or 10, or maybe I just got lucky. At some point I'm sure someone will be unlucky enough to find out how far you can go.View attachment 11151
So you only got 231 miles on a full range charge?
Crosswinds are usually worse than a direct headwind when it comes to it's affect on drag, so not all that surprising.I was a little surprised at that too, since it was mostly two lane 55 - 60 mph driving. It was VERY windy, but mostly crosswinds, very little headwinds or tailwinds. In the past when I've driven 55 I've always done significantly better than the rated range.
And I assume you charged immediately afterwards.
Traffic tends to go 75-80 mph where I live (and A/C is a must). Wonder what the standard range is going to be... probably not good.
Does it charge all the way or just to 15% and then go back to timer?Another cool item with the RAV4 EV is that if your battery is less than ~15% it will not allow you to delay the charge and charges immediately on plugging the car in. Very well thought out!!
My real-world experience suggests that at 80mph with the 85 kWh pack the Range mode range will be 200 miles +/-.
