To examine the fleet scenario in particular:
If you have multiple locations that you need to stock with batteries, how many do you keep at each?
If you have several empty batteries dropped off in a very short period you have centralized your charging bottleneck - now you need a big power source or the batteries will wait in a long queue to charge.
The battery in the 85kWh Model S is about 50% of the cost. I think this works against battery swapping instead of arguing for it because that means for every 2 spare batteries you have sitting around you could instead have another car.
An additional car in the fleet can be more easily sent to where it is needed and can go to where a charger is free.
The ideal situation for battery swapping would be two locations - separated by a distance of one charge - and cars that constantly cycle between the two locations.
I think if you have a fleet of cars, battery swapping is very likely to be the least cost effective approach - unless the situation was very close to that ideal.
