Reeler
Decade of Pure EV Driving
The Model 3 has a much smaller area to fit the battery and is at a price point where others have reduced the complexity of individual cell active cooling.
What is the volume difference between the 3 and S?The Model 3 has a much smaller area to fit the battery and is at a price point where others have reduced the complexity of individual cell active cooling.
Why?I thought it was 85% the size overall, but the battery would have to scale down more than that envelope.
Why indeed.Why?
I'm not clear on what you are arguing...Seems like you are suggesting that the physics Tesla uses (cooling system) to keep battery healthy for 10+ years should be dropped on the M3 because of initial cost. And your most recent posts indicate that there is no room for good physics because the floor plan has a kink in it.Wheel wells are the same as are many other things like seats. The floor has weird angles too. Floorboard space does not scale linearly with the size of the car.
I would hope they considered this when designing their car and the battery packs together.I think they will have plenty of room to put whatever size battery pack they want into the Model 3.
On the surface, if I understand your position, it seems contradictory to EM goal of producing fine cars. If I am missing your point, please illuminate .
The problem with doing away with active temperature management of some type is that you can seriously effect the long term health of the battery pack. Just ask early Leaf owners about battery degradation. If you want to make it cheaper that's fine, and will have to happen somewhere but if it is up to me, this is one area I think they can't cut corners on.With the modern trend being away from individual cell cooling, I think Tesla could drop it for the Model 3. Here is what supports that opinion:
The contrary argument seems to be fanboy/investor nonsense based upon EM goal of "fine cars" . . . hopes/dreams. I will be at the Gigafactory opening in July and will let you know who is right.
- The Model 3 is SIGNIFICANTLY cheaper than the other cars Tesla has sold
- The Model S/X needs to have product differentiation from the Model 3 to keep selling the advanced/expensive Model S/X
- The Model 3 is cheaper (at base price) than the Bolt which dropped individual cell cooling
- The Model 3 has a smaller area to place its battery than the Model S/X
- Lithium-based chemistries are becoming better across a larger temperature range (i.e., LEAF lizard battery)
- It has been announced that the Model 3 will use different batteries than the Model S/X
- The Gigafactory gives Tesla latitude to standardize on any size cell they want as economies of scale no longer require using an industry standard sized cell
No way it can be the same. It's smaller, there will be less room. 3/4 != 100%. However, I really doubt if Tesla will compromise on battery life. That just makes no sense.The presumption is that it will be helpful with the new cells used in the Model 3. The modern trend is away from it so I recommend folks be open minded about it.
Somehow Tesla needs to make a profit at a significantly lower price point. I know everyone wants a Model X for $35K, but logic dictates something must be different. Why would anyone buy a 5 seat Model S if a 5 seat Model 3 is the same or better?
With all due respect, I don't think anyone is expecting a Model X for 35K. Of course there will be limits to what Tesla puts in the cheapest base version of the Model 3.The presumption is that it will be helpful with the new cells used in the Model 3. The modern trend is away from it so I recommend folks be open minded about it.
Somehow Tesla needs to make a profit at a significantly lower price point. I know everyone wants a Model X for $35K, but logic dictates something must be different. Why would anyone buy a 5 seat Model S if a 5 seat Model 3 is the same or better? Model 3 buyers need to come down to reality and stop dreaming.
As far as I can tell the bolt has active thermal management for the battery. They are just chilling the bottom of the pack instead of each plate.The problem with doing away with active temperature management of some type is that you can seriously effect the long term health of the battery pack. Just ask early Leaf owners about battery degradation. If you want to make it cheaper that's fine, and will have to happen somewhere but if it is up to me, this is one area I think they can't cut corners on.
Didn't realize that Chevy had dropped it on the Bolt. It was one of the big selling points on my current Volt. That would definitely be a deal breaker if I was looking at a Bolt.
Dan
Is Reeler correct? IS the modern trend away from thermal management? I was lead to believe just the opposite - coolant piped through all Tesla batteries (so far) and the "other guys" have been burned and now are adopting cooling technology.
I really don't know what is fact vs fiction. Is there a trend against cooling?
Potential customer: I've heard that the batteries need to be changed every two years
Educated party: No, Tesla has the top notch BMS with good cooling and heating when needed
OR
Educated party: No, the batteries last, but if you want to be sure you can always drop over 100k EUR in a model S or X since the top notch BMS is reserved due to reasons
