Battery thermal management
Discussion in 'Technical' started by apacheguy, Jun 19, 2016.
Tags:
  1. apacheguy
    apacheguy S Sig #255
    So Cal
    So the past couple days have been pretty warm here in SoCal and my Model S has been conditioning the battery. I hear the fans spin up and this is further confirmed by my diagnostic logs. The DC/DC converter outputs anywhere between 300-600 watts compared to the usual 50 watts while the car is in the wake cycle.
    However, what does not make sense is that the battery temperature actually INCREASES during thermal management. It went up from 35.7 to 38.5 C in just over two hours. What's going on?
  2. scaesare
    scaesare Well-Known Member
    NoVA
    It kept it from going up by 10 degrees instead?
    • Informative x 3
  3. apacheguy
    So Cal
    I guess that's possible. I'm just surprised at how quickly the battery heats up. Everyone has assumed that the battery is such a large thermal mass that it takes much longer to heat up. What I'm seeing indicates that it very closely mimics ambient temperature.
  4. NicoletteHigh
    NicoletteHigh New Member
    SG
    Hi! I have a question about batteries. How long does it normally lasts?
  5. apacheguy
    So Cal
    So I have enough evidence to say this is not what's going on. It appears that Tesla updated the thermal controller firmware to dynamically adjust cooling set points. When driving, the cooling target is lower than when parked. Today we had a high of 95 F. The pack reached 37 C and cooling was not occurring. This is on 2.28.60
  6. Electric700
    Electric700 Active Member
    Florida, United States
    Apacheguy, you said earlier that the temperature increased from 35.7 C to 38.5 C, and just now reported that cooling does not occur at 37 C (which is in between). So, what's the cooling start threshold? Also, can you monitor to see what happens when you turn on the AC from the app and leave it on for 15 minutes? Before you turn it on, see what the battery temperature is, then after 15 minutes check the temperature again.
  7. bhzmark
    bhzmark Supporting Member
    How are you monitoring battery temperature?
  8. apacheguy
    So Cal
    Will try to do more tests. I monitor using a raspberry pi with a CAN shield that is connected to my wifi network.
  9. mchevrier
    mchevrier Member
    Montréal, Canada
    Is your
    II do not understand your answer. Is there an App that provides the battery temp?
  10. apacheguy
    So Cal
  11. mchevrier
    mchevrier Member
    Montréal, Canada
    That is out of my league.
    I have a cold temp recharging problem. While I was driving and on the phone with the Tesla Service guy, and he tells me, live, what is my battery temp. Since they access my car from a distance, I was wondering if that info was also available through the API. Seems not because all the Tesla apps would provide it.
    Thanks.
  12. apacheguy
    So Cal
    Right Tesla can access this data through a diagnostic stream but it is not available through a public API.
