Battery usage when carrying 4 heavy people
Discussion in 'The UK and Ireland' started by MaDProFF, Nov 18, 2019.
  1. MaDProFF
    MaDProFF Member
    East Sussex
    Anyone have an idea on battery drain compared to just driver and 4 heavy people in car on a 150 mile journey is there a huge difference.
  2. Adopado
    Adopado Active Member
    Scotland
    AbetterRouteplanner allows for adding weight. I'm generally less confident of ABR accuracy for winter as against summer but it should give some sort of an idea.
  3. VanillaAir_UK
    VanillaAir_UK Moderator UK and Ireland
    Surrey, UK
    I would be more worried about exceeded the gross vehicle weight. You will find the maximum vehicle occupant and cargo weight printed on the yellow sticker inside front passenger door return. It may well be exceeded with 4 heavy people and even light luggage. Not really sure what consequences are, but wouldn't want to be in an accident blamed on overloading the vehicle.
    No idea why the weight limit is so low.Tyre loadings on paper would have plenty of spare for a 100kg extra or more.
  4. Asterix187
    Asterix187 Member
    England
    The model of car would also help. An S/X would obviously be better than a 3 as the ratio of existing vs extra weight will be less in an S/X.
  5. phillcom3
    phillcom3 Member
    preston
    1/2mv^2 its realy not gpoing to make a big difference. what does is your speed. just drive slower
  6. Jason71
    Jason71 Active Member
    Shropshire
    I was going to say the same thing + Maybe they will help to keep the cabin warm and thus reduce the heating KW's :)
    There might be an argument for increasing the tyre pressures though to compensate for the additional weight to minimise any increase in rolling resistance, especially if we are talking motorway driving.
  7. nufan
    nufan Member
    UK
    If it’s a motorway/constant-ish speed journey - drag’s also proportional to speed squared - and the 4 heavies won’t make a jot of difference to that (may lower your suspension to make things sportier?!).
    Hadn’t done it until just now - but square 65, then 85, ignoring units to demonstrate to yourself. I might not be in the fast lane much on long-hauls anymore.
    The carrying weight constraint on M3: off to look it up - but started me thinking about different elements of car - i.e Hold mode vs gravity; momentum vs motor. Can’t see anything there though, as I understand torque is good on these cars. Mentioning in case anyone else can see something in that vein...
  8. nufan
    nufan Member
    UK
    Reading around - the structures of the boot/frunk may be in play in the calculation. Lots of talk in other places of high loading though (albeit, I take on board the insurance implications). Even then people were impressed with acceleration/braking - so that might be the wrong lead.
    Pinching from another’s posting:
    Caution: To avoid damage, never load more than 130 lbs (60 kg) on the rear load floor (above the lower trunk compartment) or more than 285 lbs (130
    kg) in the lower trunk compartment. Doing so can cause damage.
    Page 149: Do not exceed the maximum front trunk load weight of 55 lbs (25 kg).”
    Boot: something to do with a honeycomb upper/lower divider you have to take care over.
