This is good to know.I park outside and today it's -4.6 C. All I do is insure the charge stops close to when I'm ready to leave, and preheat the car for two or three 15 minute cycles with range mode off. This will allow close to 30 kW of regen (about 50% or maximum) for the first few miles on more or less level ground. If you were going downhill, the regen would warm the battery up even faster than it does for me as the motor would be creating heat. If I lived where you did, I'd probably still have to use the friction brakes a bit, but not that much.
However, if it's below freezing, the car was already charged 24 hours prior, and you just get in the car and start driving, how much regen do you typically see? How long before the regen reaches a "reasonable" level?
I ask because our family routines vary considerably, I don't have a regular commute, and I can't expect other family members to do a lot of prep work to warm up the battery before driving. I think they'll be willing to preheat the car for 15-30 minutes from the app, though not necessary on "shore" power. I know from LEAF experience that timing the end of charging to coincide with departure is good to do, but that's been sort of hit and miss for us. So we end up charging to 80% whether we need to or not, and the car sits at that level of charge until it gets used at some point each day or maybe not until the next day.
