So, back in 2011 you will remember I drove a red Roadster to Edinburgh (then across to Ireland and back to London). That Roadster was registration LJ60 HUO.
Two weeks ago a Roadster finally appeared on Autotrader at a price I was prepared to pay. They tried to disguise the plate but they weren't fooling me.
LJ60 HUO is now sitting charging outside. Well it would have been rude not to. :biggrin:
You might call it the world's most comprehensive test drive.
Nice 1 David,
This car was my backup, (it popped up for sale the w/e before I collected mine) ... lovely owner and history (she's still got another Roadster in France, I understand) - well done !!
AND we are almost neighbours (Poole)... I run up and down the M3 all the time .... and the ecotricity fast chargers are damn useful !
If you haven't got
a CAN, get one then along with a J1772 to Type 2 cable: you can charge at 60Amps (or more
).. HPC territory !
as I posted here >
Charging Tesla Roadster at 60A on AC rapids | Speak EV - Electric Car Forums
The cable is a standard J1772 to Type2 with 3 mods:
1. Reduce length of Type 2 end by 14mm (cut square and accurately) ... so that it fitts ALL the way into Ecotricity FAST charger, Female plug.
2. Check wire diameter, and if necessary Double up cable, (or add extra, 3 x 6mm square cables) to increase CSA to take 60A without any heat/voltage drop ... or... (at your own risk) accept the heat increase/slight voltage drop using 6mm CSA (32A) cables.
3. Change the sensing resistor in the Type2 Plug (to 100 ohm for 63A).
I intend to add a simple catch to augment the friction grip of the Type2 plug & socket - maybe a rubber sheath.
must kick each others tyres sometime :smile:
Mark
