Couple of notes, the UP damping adjustable shocks are designed to be of fixed height. You can put aftermarket springs on them but the dampers themselves are not intended to be height adjustable. This damper was produced to fill a void for the SS class of SCCA Solo 2 afaik.
In addition to setting up these independent ride height and spring preload type of coilovers you need to take into account critical shock lengths, bump vs droop, etc.... It's not as simple as saying you have 4" of bump and can adjust the height at the lower bracket. Now the rear damper gets even more complicated because if the damper length isn't set correctly, considering it's divorced from the spring, you can end up with a lot of issues. This is why most euro companies like KW have fixed damper lengths. It takes all of that potential problems out of the equation. I too was sold by the fact that you can retain all your bump and still be very low but in all reality droop is so important to your ride quality not to mention rebound valving curves. With that said on the Teslas the shock lengths should be set to a specific measurement and if further ride height adjustments need to be made it should be done at the spring. The way the spring rates appear on the BC's you might need helper springs up there to obtain some droop. All this will be accounted for when I begin custom spec'ing some BC's to help those who need a real budget monotube single adjustable coilover.
