I’ve seen it discussed that charging will warm the battery up to allow for better temperatures for winter charging. Also I’ve read that charging before you drive can help you preheat the pack.
But is it possible to keep the pack warm all the time by keeping the charge rate around 10A~ (depending) to provide slow and steady charging throughout the entire night? Thus resulting in a better quality of charge, maintenance of warmer temps in the pack, and providing a full charge by morning?
I wonder if this can be done, because just like the Regen charge rate staying capped at sub ~50w in cooler temps, will the pack get warm enough during that slow of a charge since it isn’t charging at the usual higher rate?
I usually deplete about 20-30% battery per weekday, and the weather so far is getting to the 20* area here in my case, so I’d say others in even colder locations would benefit from this as well.
