GasDoc
When you inspect the hive, place your inner cover upside down on the ground near the hive, then pull off each box and set it on the cover or the next box at a slight angle (not perpendicular so that bees can fall into the grass, but not parallel either where the propolis makes everything stick together). When you get to the primary brood body, stack it on top, then place your inner cover over it so you don't lose a lot of bees in the air. If there are bees on the bottom board, gently shake them into the hive, replace the board, then restore the hive.
I just have the one brood super right now. So I'll smoke through the inner cover, pick it up and place it on my upside down outer cover, replace the bottom board and put things back together. I'm assuming that any bees on my old bottom board, I can just brush into the top of the hive when I'm putting it back together.
