Belgium and the Netherlands: Public Charging infrastructure
Discussion in 'Belgium and the Netherlands' started by widodh, Nov 19, 2013.
  1. widodh
    widodh Model S 85 and 100D
    Venlo, NL
    For the international readers
    The Netherlands is one of the leaders as it comes to installing public charging infrastructure.
    Currently there are about 3600 public charging stations installed. 90% of them deliver 11kW (8 hour for a 85kWh Model S) of power (3-phase 16A) on two outlets.
    The Dutch government has various incentives for EVs and charging infrastructure.
    Charging at these stations can be done using a RFID card which can be acquired at almost all utility companies here. Down here a couple of links where you can get these RFID cards:
    * Essent (Company from German RWE)
    * Nuon (Energy Company)
    * Blue Corner (Belgium)
    * Laadpas.com (Comparison between companies)
    * ZE Rijden.nl
    A overview of all charging locations can be found at Oplaadpalen.nl which also has charging stations in Belgium.
    Some of these stations are also mentioned on OpenChargeMap.org and ChargeMap.com
    The rest of this topic will probably be in Dutch, but feel free to ask questions in English! Should you also a foreigner want to come to NL or BE and want to find out how to charge, ASK!
    Note: All charging stations have a Type 2 socket!
    FAQ (EN)
    Q: What cables or socket are used on the Charging Stations?
    A: All charging stations have a Type 2 socket and do NOT have fixed cables. So bring your own Type 2 cable!
    Q: Can I charge a free charging stations without a RFID card?
    A: No, although these stations are free, they still require a RFID card to allow you access
    Q: Can I charge with a German card?
    A: Roaming is being worked on. It might be that RFID cars from RWE work in the Netherlands, but it's not guaranteed.
    For the Dutch and Belgian readers
    Nu het steeds drukker wordt in de andere topics is het wel zo verstandig om discussies over publiek opladen hier te houden.
    FAQ (NL)
    V: Welke kabels heb ik nodig om publiek te laden?
    A: Alle publieke laadpalen hebben een Type 2 socket. Voor een Model S heb je dan ook een Type 2 laadkabel nodig die te koop is op laadkabelwinkel.nl. De UMC van Tesla gebruik je NIET bij publiek laden.
    V: Welke pas heb ik nodig?
    A: Zie het lijstje hier boven. Vragen of toevoegingen? Post ze hier onder!
    V: Hoe weet ik of een laadpaal betrouwbaar is?
    A: Kijk altijd eerst op bijv Oplaadpalen.nl of er reviews of foto's zijn van de betreffende laadpaal. Plaats uiteraard ook eigen reviews en foto's om andere te helpen!
    Wat hier verder te bespreken:
    * Welke palen werken?
    * Waar vind ik palen?
    * Welke pas heb ik nodig?
    * Welke kabels heb ik nodig?
  2. ResB
    ResB Member
    Flevoland
    Mijn auto net ergens ingeplugd en terug naar kantoor gegaan. Zo te zien vanaf mijn iphone, laadt hij maar 6/16A? Waarom is dit zo? Toen ik hem niet inplugde was de A volgens het scherm 6A.
    Moet ik nou beslist terug gaan om dit aan te passen, of kan dit ook op een andere manier?
    Laadt met 6A maar 19km/u...
  3. Marketeer
    Marketeer Member
    Weert
    Wie kent er een app met laadpalen in europa? Laadpalen.nl geeft alleen info over NL en B. Moet begin december naar Harnes in Frankrijk en wil eigenlijk wel met mijn MS gaan. Als ik de laadpas van Newmotion gebruik, werkt die dan overal of is het verstandig om een tweede pas achter de hand te hebben (of de ouderwetse creditcard of bankpas?)
  4. JoeNe
    JoeNe EU P 1662
    Wijgmaal, Belgium, Europe
    Was er geen probleem met EV-boxen die langzaam hun stroom opbouwen en de Model S die niet volgde.
    Voorlopige oplossing was blijven wachten in de auto tot de stroom opgebouwd is en mee naar boven scrollen
    http://chargemap.com/ zou je moeten helpen
  5. pebell
    pebell Member
    Leiden, The Netherlands
    Probeer "PlugSurfing" eens. Ik krijg daar ook laadpalen in (bijv) Duitsland en Frankrijk te zien.
    Edit:
    Nou ja, erg weinig in Frankrijk, eigenlijk. Duitsland, Luxemburg, Zwitserland, Italie, Engeland, overal behalve Frankrijk.
  6. widodh
    Venlo, NL
    Ik gebruik al bijna 3 jaar de publieke infra met de Roadster van mijn collega en nu ook al met grote regelmaat met de S publieke infra.
    Met mijn "Essent Vaak" pas nog nooit problemen gehad. Laadpunten werken altijd en heb prima kunnen laden. ICE'ing wel gezien, maar áls ik bij de paal kon dan werkte deze ook.
    Mijn andere collega (ook met een S) laad ENKEL publiek en heeft in 7 weken ook al weer 5500km op de teller staan.
    Ik ga morgen overigens hier laden: Elektrische auto opladen op een P+R - Gemeente Amsterdam
    40 (!!!) publieke laadpunten op één plek en vanaf daar met de Metro naar het Damrak waar ik moet zijn voor een 3-daagse conferentie in de Beurs van Berlage.
  7. gelden
    gelden Well-Known Member
    Breda, Netherlands
    weet iemand of ik de New motion of Essent (soms) pas kan gebruiken bij een Essent laadpaal in Luxemburg?
  8. ResB
    ResB Member
    Flevoland
    Ik heb gister aan de laadpaal gehangen in Heerlen en vandaag in Almere. Laden werkt prima, alleen bij de laadpalen die er zo uit zien (als in de bijgevoegde foto) stopt het laden plots na een aantal minuten... Iemand anders ook last van gehad bij deze palen? Bij andere palen werkt het prima (tot zover).
  9. jetje
    jetje rkc waalwijk
    noord brabant
    Die paal heb ik voor de deur staan! Dan gaat de ring knipperen! Betekend communicatiefout met de auto!
    Als je het amp 1 onder de Max zet die de auto aangeeft is het probleem verholpen!
    Bij mij is 1 kant 3x25 amp heb hem dus op 3x24 staan!
  10. widodh
    Venlo, NL
    Heb je die al gemeld aan E-Laad? Want zulke problemen moeten uiteraard wel verholpen worden.
  11. L@urens
    [email protected] Family, Racing, Karting, MTBing
    Enschede, NL
    #11 [email protected], Nov 19, 2013
    Q-Park Bijenkorf heeft een berg lolo's hangen, direct naast Beurs van Berlage...
  12. widodh
    Venlo, NL
    Ik vind de Bijenkorf alleen een drama om te bereiken en vreselijk duur om te parkeren.
    Ik pak daarom wel gewoon de P+R :)
  13. jetje
    jetje rkc waalwijk
    noord brabant
    Is gemeld kunnen ze niks aan doen, is iets tussen de paal en model s! Dit is ook sind de update (de vorige dan) daarvoor nooit problemen gehad! Dus ik vermoed eerder models probleem! Maar voor de monsen als het vaker gebeurt blijf melden aan e-laad
  14. ResB
    ResB Member
    Flevoland
    Ok bedankt voor de tip! Omdat ik dit niet wist heb ik maandagnacht in de auto geslapen aan een rotlaadpaaltje in Valkenswaard omdat ik niet thuis kon komen... De laadpaal in Heerlen kapte er namelijk iedere keer mee en had nog maar 70km bereik.
    Kunnen we voor Model S owners geen overzicht maken van alle laadpalen die goed werken met onze wagens, en die onze wagens een beetje vermogen geven? Alleen laadpalen die we zelf hebben uitgetest. Of gewoon reviews posten op oplaadpalen.nl?
  15. martinve
    martinve Active Member
    Heerlen, NL
    Volgende keer gewoon Tesla bellen. Vaak hebben ze wel tips beschikbaar om de meeste euvels te verhelpen.
    Of Tapatalk installeren en vragen via het forum hier. De kennis die hier beschikbaar is, is vaak nog uitgebreider dan die van Tesla.
  16. pebell
    pebell Member
    In ieder geval reviews op oplaadpalen.nl. Als alle Tesla rijders dat structureel doen, is deze database binnen no time een stuk verbeterd (voor deze doelgroep).
  17. ResB
    ResB Member
    Flevoland
    Heb zojuist aan alle laadpalen waar ik tot zover aan heb gehangen een review geschreven.
  18. widodh
    Venlo, NL
    Helemaal super!
    Ik sta nu te laden bij Zuidpark Amsterdam (Spaklerweg 24) en dat is BIZAR!
    Taxi-E heeft hij thuisbasis daar, maar het ziet er zo uit:
    Wat staat er?
    - 4 CHAdeMO snelladers
    - 40 3x32A Keba laders
    Het laden is gratis en parkeren kost 3 euro per uur. Heb de Metro gepakt naar Amsterdam centraal.
    Maar 40 (!!!) 32A punten, dat is bizar.
  19. SIG116
    SIG116 Member
    Westzaan, The Netherlands
    En dan straks met de elektrische taxi weer terug :smile:
  20. ResB
    ResB Member
    Flevoland
    Ziet er goed uit. Misschien klein beetje off-topic, maar als je iets bent vergeten uit je auto en je drukt 2 keer op het dak van de sleutel om de auto te openen, stopt bij jullie het laden dan ook?
