I did some searching but couldn't replicate my issue. It's been below freezing the past few days and nights, and when I plugged in to do my regular 2am scheduled charge the other night, it simply didn't. Instead, upon checking the app in the morning, it read the same or similar mileage remaining as when I plugged in, and stated something like, "Starting to charge." When I went out to check what was up, there was a red light illuminating within the green stream of lights on the UMC. I went in the car, turned off scheduled charging, and it initiated as it normally would in cold weather, building up volts and amps, then moments later, miles per hour of charge, slowly reaching around 29 mphc.
Cold does seem to be the culprit here, but I don't feel this is normal. Can anyone help?
Also, a quick afterthought I'll also throw in, my last SoC was 193mi, down from the 197 norm of the daily, not trip, charge. Car only has a few thousand miles on it. Does this happen when it's cold and will some of those top end miles return? Thanks so much.
