Bent Control Arm
Discussion in 'Model X: Driving Dynamics' started by J's X, Nov 10, 2016.
  1. J's X
    J's X Member
    Los Angeles
    My pretty new Model X was in for some warranty work and they tell me I have a bent control arm. Not aware of hitting any potholes or anything that would have caused it and can't help wondering if anyone else has had that problem?
  2. K-MTG
    K-MTG Sunshade Captain of TMC
    Irvine, CA
    Is that covered under warranty? Did you notice any driving issues?
  3. Xenoilphobe
    Xenoilphobe Active Member
    Fairfax County Virginia
    Curb impact usually causes bent control arms..
  4. J's X
    J's X Member
    Los Angeles
    No, not under warranty and no control issues. Just surprised. Wondered if arm is not as strong as it should be? It's a heavy car.
  5. J's X
    J's X Member
    Los Angeles
    Service didn't think a curb issue would do it, and not aware of any impact (e.g., pot holes, etc.) Just made me wonder about the strength of the control arm in a very heavy vehicle and if it might damage easily. Thanks for the video.
  6. Az_Rael
    Az_Rael Supporting Member
    Palmdale, CA
    #6 Az_Rael, Nov 22, 2016
    Model X Front Suspension Failure
    A previously reported control arm problem on an X, FYI
    (FYI, I expect this thread will quickly devolve. Suspension issues are a sensitive subject here)
  7. JohnSnowNW
    JohnSnowNW Active Member
    Minnesota
    Misinformation is what's sensitive. As well the idea that Tesla engineers don't know how to build components to withstand normal driving forces.
  8. Az_Rael
    Palmdale, CA
    Understood, but as far as I could tell on the locked thread I linked, the OP there was real and had a real failure. This board sometimes reacts very negatively very quickly to suspension posts just due to that one troll. Someone who doesn't come here much then posts a problem might be caught off guard by that.
  9. Colby Boles
    Colby Boles Member
    San Francisco, CA
    Speaking from experience rally racing where crashes and damage are quite common, control arms are designed to bend before transmitting damage to subframes and other suspension mounting points where things are much harder to fix. Much better to just have an easily replaceable control arm.
    Should it bend without any noticeable impact? That is still a valid question...
  10. J's X
    J's X Member
    Los Angeles
    So, nobody else out there with a bent control arm on an X ?
  11. bhzmark
    bhzmark Supporting Member
    I know a a model S that rec'd a bent control arm from a run in with a big pothole. It's not that bad and was swapped out easily. A common enough repair that they stock the parts.
  12. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    Apparently, it is not a widespread issue...
