I was in the wheel repair business for 10 years before I sold it and retired. Low profile tires allow the inside of the rim to more easily bend when encountering road hazards like pot holes. Less rubber between the tire and wheel means bends are more likley. Usually bends are on the inside because there is no support.
With the proper equipment, technique and training, most inside bands are repairable...I've personally successfully repaired thousands. Much cheaper than a new wheel.
Inside bends are very easy to see by spinning the wheel. I'd say jack the car up, put it in tow mode, and have someone spin the wheel while you look on the inside. Taking the wheel off of the car and spinning it up on a wheel balancer also works.
Google "wheel repair near me" . My shop was a franchise that has locations all over the USA...Kwicksilver Wheel Repair. Make sure they heat up the wheel during the repair process, otherwise the wheel will probably crack. Fortunately, cracks can also be repaired, again I've successfully welded on thousands of wheels.
