Best All News Station on Tunein or Slacker
Discussion in 'Model S: User Interface' started by Soundchasr, Jul 10, 2016.
  1. Soundchasr
    Soundchasr Member
    Very close
    I can't seem to find a decent news channel (something like CNN or Headline News). Any suggestions?
    Thanks!
  2. msnow
    msnow Active Member
    SoCal
    CNN on TuneIn :)
  3. Soundchasr
    Soundchasr Member
    Very close
    Really? Why can't I find it?
  4. modelx007
    modelx007 Member
    boca raton, fl
    Because it is burried and you actually have to hunt it down... believe you manually select news then talk and it is down the list on the right a biy after fox news talk. Had same issue finding it as you.
  5. msnow
    msnow Active Member
    SoCal
    T
    Try installing the app on your phone or login to their site, create your own free ID. They have a search feature and just search for "CNN" (they also have HLN). Once you find it click "follow station". Before you click out, up your bandwidth to the highest setting for the best sound. Login to the Tesla app in Settings/Apps/Media with your new personal ID and the "followed station" should show up as a favorite in Media Player. You can find tons of good stations in TuneIn by searching this way.
  6. commasign
    commasign Tesla Superfan
    Davis, CA
    ABC News on slacker lets you skip to the next story. Only drawback is there's a finite amount of content each day so after a while you start hearing the same story. But I guess that happens with live radio too. At least here you can skip whenever you want.
    • Disagree x 1
  7. Soundchasr
    Soundchasr Member
    Very close
    Awesome! Any other good stations your recommend?
  8. msnow
    msnow Active Member
    SoCal
    There are so many to choose from I wouldn't know where to start. I found all my favorite local AM/FM music and news stations and the clarity is so much better than AM/FM radio. Slacker, as was pointed out, has some too. ESPN Radio, ABC and CBS News etc.
  9. mikeash
    mikeash Active Member
    Fairfax, VA, USA
    I enjoy the BBC World Service stream, especially when I can't stand to hear any more ridiculous domestic issues on American stations and need a change.
  10. Jtrader
    Jtrader Member
    KY
    Except that in-car login doesn't work for Tunein anymore.
  11. msnow
    msnow Active Member
    SoCal
    Works for me. I just tried it.
  12. UberEV1
    UberEV1 Member
    San Jose, CA
    Don't log out! If you do, it may be difficult to log back in (I have had an open ticket on this for almost 2 months - now escalated to the Developers). There are some bugs on the Tune-In side that need to be worked out, including not being able to play some content (high bandwidth broadcast error message, when it shouldn't be) and no easy way to refresh the favorites list to reveal recently added podcast episodes. I am confident it will get resolved, but is likely in the firmware coding.
    I found the easiest way to manage TuneIn content was to set up an account at TuneIn (free), select your favorite stations, podcasts, etc. using your home computer, then logging into TuneIn on the car (settings/media page). When working properly, this will copy all your TuneIn selected favorites into the Media App on the car's main screen for easy access. Trying to search for specific TuneIn content via the car's Media App can be nearly impossible (no search feature, only embedded category menus to sift through millions of content choices).
    With that said, I have confidence these bugs will be worked out and the search capability will be improved (if it works on Slacker, it must be possible to make it work on TuneIn).
  13. Jtrader
    Jtrader Member
    KY
    Have you logged out and logged in recently? What version do you have? I have a MS 85D v7.1 (2.24.102) and it will not ever let me login like it used to. There are several threads indicating that many others are having the same problem. I emailed TuneIn and they said it was a known issue on Tesla's side. There are several podcasts I want to listen to that can only be accessed by logging in and going to Favorites.
  14. msnow
    msnow Active Member
    SoCal
    See my signature, 90D, same firmware as you. I checked the app and I'm still logged in with my personal ID but since you guys are all having problems I'm going to take the advice of @UberEV1 upthread and not log out :)
  15. smilepak
    smilepak Active Member
    Eastvale, CA
    CNN is on TuneIn, I listen to it often. There is a FOX Talk News. It is different than the FOX Talk News on Cable Network, but occasionally there Bill ORielly and others.
    I have yet to find MS NBC or CNBC on TuneIn.
    There USA News and Bloomberg.
