Best charging method during Covid Quarantine?
BlueKam_M3LR
12
3
NJ
Due to the covid pandemic, I have been working from home for the past few weeks and have not needed to drive my Model 3 that much at all. I have 280 miles on the odometer (took deliver on 3/13) and currently at 60% battery charge. I leave sentry mode on at all times so the battery does drain slowly over time. I have a Tesla wall connector installed at my house so I can charge anytime if needed.
What is the best practice to maintain my battery health if not driving the car for many days/ weeks? Should I keep the charger plugged in and set to 65% charge rate even though I am not driving for many days (I assume the battery would drain from idling/ sentry mode and then the charger would maintain 65% charge?)? Or should I charge to 65% then unplug the charger and let it drain from sitting idle with sentry mode on until it reaches 30% then charge again to 65% and repeat?
I am sad I don't get to drive my Model 3 and I want to make sure I am not damaging the battery health by letting the car sit for many days without use. Thanks.
KenC
3,278
2,993
Maine
Choice 1 is best.
Reactions: BlueKam_M3LR
jjrandorin
Nov 28, 2018
7,197
7,979
Riverside Co. CA
Tesla specifically advises choice 1 and says that there is no benefit (their words) to "running it down to charge it back up" Also their words
mbp11
355
183
SF Bay Area
I am a physician in the SF bay area and we are anticipating a surge of virus cases in the next 2-3 weeks. Drive-by testings of the population in this area have actually showed 25% of people who got tested have the virus, so the prevalence of the virus is higher than reported in the population. Since I am covering several hospitals, I am suffering from range anxiety, so I am trying to keep the charge about 90% when I can, so I can get to and from comfortably and charge at night.
jonquiljo
1,061
495
SF Bay Area - Marin
It depends on whether you can get home at night. Are you doing long shifts and getting some sleep at a hospital, or do you work in more regular shifts?
The reason I say this is even at 110V (regular wall outlet) you will charge 5MPH. So in 8 hours, you can boost up 40 miles. If you have a way to plug in at a hospital, you have it even better. If you get home sometimes and have a 240V charge outlet, you can get a lot more mileage. So it depends on your hours, availability, and type of charging available. Good luck and thanks for being there for us!
mrau
Authorized Driver
Nov 12, 2018
384
745
Mid-Michigan
As stated, it is best to leave the car plugged in when you can. Set charge level between 80-90%. If you are parked inside a garage, no need for Sentry mode to be on. You can change settings to automatically exclude your home and/or work from Sentry. Your car alarm system will still work even if Sentry is off.
mbp11
355
183
SF Bay Area
Thanks, Jonquiljo. I am a hospital based surgeon, working every day and some overnights, and can charge at home, and at the hospitals I work (level 2 at the hospitals and 240 v 15 amp circuit at home). I charge overnight easily at home and I am just leaving it at 90 for now. If things get busy I will have more than enough to get around, I am very lucky.
BlueKam_M3LR
12
3
NJ
Thank you all for the replies and information, I will keep the car plugged in everyday.
And Thank you Mbp11 for saving lives on a daily basis and especially during these scary times..you are a true hero.
Reactions: Electric700
Janus
215
102
Bay Area
Personally, I'm leaving Sentry Mode on all the time during the pandemic. In the Bay Area, there's been a noticeable jump in car break-ins. With everyone inside, and few people on the roads, all these cars parked in driveways and apartment lots are easy targets.
XLR82XS
D M C
Jul 26, 2019
3,071
1,698
SWFL | Vegas
Exactly. Too many threads here about charging/plugging in - follow the owners manual regarding charging.
ElectricIAC
Devil’s Advocate
Dec 31, 2019
2,192
518
DFW
Keep it plugged in, move slider to 90% and forget it.
2018 w/24K doing this and haven’t lost a rated mile of charge since I acquired it.
