I might buy one of this as I really like the 2 cams idea
http://www.garmin.com.tw/products/GDR/gdr190/
Looks promising. I'll have TWO of those, one in the rear window as well (although, then there is not much to see any more from that small window)
Keeps recording 90 minutes after power is shut down (for parking accidents), 200 degrees field of view.
I cannot see it on any English pages, the US Garmin store only has a single camera version. Can the menu be changed to English? The manual from that page is in TC only.
It says the program for viewing the recordings is a "PC Tool", yet the anonymous "PC" in the picture looks more like a Macbook. Would someone guess/know whether there is a Mac version also of that "PC Tool"? In the manual it says
注意:
1.僅適用於Windows作業系統(Windows XP/Vista/7) 2.電腦端播放軟體也可至Garmin台灣官網 Garmin | United States | Home. tw/software 下載安裝
Which I think means Windows XP/Vista/7 only
It all depends on where you connect the wiring, permanent 12V or on-only. This one just has it's own built in battery, yet I think if it runs the units internal battery down for every time you park, that battery won't last too long.Id like to find one that stays on all the time. I also wouldn't mind infra red capability front and rear.
I currently have the BlackVue DR500GW-HD, but I have pledged for the CENTR on Kickstarter. It's a panoramic video camera. I'm thinking of mounting it in the center of the car: CENTR: Interactive Panoramic Video in the Palm of Your Hand by CENTR Camera Kickstarter
One thing I liked about the Mobius is that it usus only ~500ma of power.
Rechargeable LIPO Battery (500mah), with Battery Charger Manage IC
No battery, powered on, not recording: 225mA @ 4.97v (1.12 watts)
No battery, recording 1080p: 305mA @ 4.97v (1.51 watts)
Battery being charged from flat, powered off: 186mA @ 4.97v (0.92 watts)
Battery being charged from flat, recording 1080p: average 505mA @ 4.95v (2.5 watts)
I'm just saying this as some might want to have the camera record continuously, in case of vandalism or parking lot accidents while you are away from your car. If you are parked outside, a simple solar panel would keep the 12V battery topped up, but that's no good if you are in a garage. Obviously, if your car is plugged in, it's no issue either.
Does Mobius support loop recording where it only saves the video after some impact (before AND after, i.e. 5 seconds before, 20 seconds after)? This way, the car could be parked for weeks, and only record that instant when someone rams or pushes the car.
No, Mobius is very basic - it doesn't have any motion detection. It does have loop recording. I wire mine to the switched 12V line so it shuts itself down when the car is off.
Side note: Actually, on the roadster it is pretty sweet. There are actually 3 +12V lines - (1) car on, (2) car off and sleeping, (3) car off but awake. The first only has power when ignition is on, the second has power always, and the third has power while the coolant pump is running (typically when charging, or for 5 minutes after ignition is turned off). All 3 of those 12V lines are available for tapping. My Parrot Asteroid head unit is actually wired to the permanent 12V line (2) and has a motion detector. If the Parrot detects motion, it wakes up for 1 minute to be ready for the ignition to come on so as to be able to startup quicker. If the ignition doesn't come on within a minute, the Parrot goes back to sleep. The side-effect is that when the Parrot detects motion, it powers up its USB ports - and that is where I have the Mobius wired. End result is that if the car is hit, the Parrot comes on and powers up the Mobius for a minute or two. The Mobius won't catch the collision, but it will record what happened just after.
I considered to get a smaller 6V non-spillable deep cycle battery (AGM or something), as there is plenty of baggage storage. Attach a solar panel inside the baggage compartment or maybe even under the aft/middle part of the sunroof, to keep it topped off, as well as connected to a 12V source only for when the car is on (or also when plugged in, even better, if possible), with a 12V to 6V one-way charging shunt. This way, it can run out of power completely, without affecting the cars own 12V battery. Worst case scenario would be weeks of parking inside a garage, and not plugged in, as there would be neither charger nor solar power, yet at least, it won't affect the car itself. A 5W solar panel should be sufficient to keep it going forever.
Imagine the car recording any time when on/driving, and also when being pushed/moved? That would be a really good protection, unless of course the cameras are stolen/damaged/overwritten.
Another option is to use the 12V onboard, with a solar panel, but that still won't keep the car from running out of power if parked inside and not plugged in.
Wouldn't it be easier to use a USB battery pack to power the Camera and plug the pack to the 12V battery for recharge?
Basically, that's what I wrote, except I want it to be automatic, work also when the car is parked, and have no impact on the 12V battery of the car itself. Whether it's a "USB battery" or 6V AGM, is not much difference, but it better be a deep cycle battery if there is any have it's going to be run down to a low charge.
