Best Deal I have found for winter tires
Discussion in 'Canada' started by TOFLYIN, Aug 22, 2018.
  1. TOFLYIN
    TOFLYIN Member
    Toronto
    I have been a fan of Hakkapeliitta winter tires since I put them on my 2012 Volt. Ran them for 5 winters without a problem and loved them. Started looking for them in Toronto and found out that Kal Tire has a strangle hold on them. They want $290 per. When I lived in Guelph, I dealt with Dettmer tires quite a bit. Very knowledgeable (especially Mike at the Eramosa/Stevenson location). So I called them up and they ordered mine in (they will apparently be arriving tomorrow) and they will store them for me until I get them installed in November. $258 each for the R3's @ 235/45/18. Mike said there might be a rebate by then as well, but he currently only shows availability of 100 tires in this size. It is worth the drive to Guelph for me from Toronto (I can see old friends while I am there), but if you are near Guelph give them a call. I verified that they know how to jack a Tesla and they are sourcing TPMS for me. Now to find a nice set of winter rims!
  2. Tony_YYZ
    Tony_YYZ Active Member
    Caledon, ON Canada
    Did you pay for them in full now?
  3. mknox
    mknox Well-Known Member
    Toronto, ON
    Thanks for the tip. I too am a big fan of the Hakkas having used them for 5 winters on my Model S.
  4. 5_+JqckQttqck
    5_+JqckQttqck Active Member
    Toronto
    Sounds like a good deal $30 off per tire. Do they install/balance if I bring my own rims :)?
  5. Canuck
    Canuck Well-Known Member
    South Surrey, BC
    When shopping for rims and winter tires a few years back, both Ka Tire and 1010Tires asked for my VIN number since universal TPMS work fine but are programmed depending on your VIN, then programmed in car. If a tire shop doesn't know that, I wouldn't want them jacking up my Tesla since they clearly haven't worked on many.
  6. mknox
    Toronto, ON
    For those who may not be aware, Members in Good Standing of the Ontario Tesla Owners Club enjoy a Kal Tire discount, as well as promos and discounts from a number of other sponsors.
    Details here.
    • Informative x 2
  7. lotuni
    lotuni Member
    Edmonton, AB
    Does anyone know the CAD$ for the 18" Aero wheels only from Telsa? I want to get the Aero's but not a fan of the Pirelli winter SottoZero. What would the order timeframe be for wheels to Canada?
  8. mknox
    Toronto, ON
    I've got good news and bad news. I stopped by my local Service Center to ask that very question. The good news is, yes you can order rims separately. The bad news is they couldn't give me a price because there is a pending price increase and Tesla hasn't announced Canadian pricing yet. My gut is that Tesla rims will be very expensive compared to aftermarket.
  9. Birdman325
    Birdman325 Member
    Toronto, Canada
    Which would make sense given that they currently charge $2,400 for the Aero 18" Winter wheels and tire combo package. Convenient but pricey.
  10. Switzch
    Switzch Member
    Toronto, Canada
    I called Tesla Oakville service this morning and they quoted me $250 for each rim (no rubber). This is for M3 18" Aero. They don't have any in stock but he mentioned a shipment coming in a few weeks. He also mentioned they would NOT install the tire on the rim.
  11. Kenypowa
    Kenypowa Member
    Calgary, AB
    Thanks for the heads up. I just placed an order for the rims, still at $250/rim.
    In Calgary SC, they are charging $150 to mount the tires.
  12. felixculpas
    felixculpas Member
    Ontario, Canada
    I've been using H2's on a hybrid SUV for the past 6 winters and got them from Kal Tire. I have a cancelled M3 order. Will probably re-load in the fall if the feds introduce anything but otherwise in the spring and will join the club then. Keen to try out the H3's. Curious as to what the discount is if you could mention or PM me. Thanks.
  13. lotuni
    lotuni Member
    Edmonton, AB
    Hum... maybe I should order the rims already?? (waiting for Model 3 Dual) Can I even order if I dont have a VIN yet?
    They Aero wheels are $200 USD each in the US so that lines up with the exchange rate at $250 CAD and you need TPMS as well at $280 USD for 4 of them. So the $2400 CAD is not that far off for what you get compared to US pricing.
    My wife had Pirelli winter tires on her SUV (not the SottoZero ones however) and one of them delaminated last winter.... left a sour taste with Pirelli tires :(
  14. Darthbenji
    Darthbenji Member
    Ontario
    Can someone share what the discount amount is from Kal tire if you join the owners club?
  15. Birdman325
    Birdman325 Member
    Toronto, Canada
    So assume $US280 per wheel with sensor is about CDN$370 x 4 = $1,480 for the 4 wheels plus sensors. That means each tire is about CDN$250 to get to the CDN $2,400 total for the package.
  16. Birdman325
    Birdman325 Member
    Toronto, Canada
  17. lotuni
    lotuni Member
    Edmonton, AB
    The 18" winter package is $2K USD so that is an exchange rate to CAD 1.2.... not bad
  18. Viv ki Bijli
    Viv ki Bijli Member
    Mississauga
    What was the overall cost and if they can really do Tesla?
    I have ordered from Tesla at 2400 + taxes so wanted to check the difference
  19. 5_+JqckQttqck
    Toronto
    The Tesla's winter package is a decent deal if you're okay with the Pirellis.
    My current set of rims + TPMS + hub ring is already ~700 CAD. Slip on the four R3's + taxes it'll be close to 2000 CAD total. Doing your own thing really saves about $100 per tire and requires a lot of research and mucking around.
    Key specs of Rims and Tires.
    Rims
    1700+ load index / 18" x (7.5 to 8.5) / 5x114.3 bolt pattern / 64.1 hub diameter.
    Tires
    WT 98 + (using the R3 as an example from the Kal Tire website)
    Also need to get the tires on the rims and balanced. So really only saving a couple hundred bucks. It would actually cost more if you get a nice looking set of rims that can handle the weight of the Model 3.
    At the end of the day, it's looks of the rims that'll be the major difference.
  20. TOFLYIN
    TOFLYIN Member
    Toronto
    I haven't paid for them yet, but in the past their prices included install and balance. So figure $80 per for TPMS unless I can find them cheaper and $250 per for a decent winter rim so I am banking on around $2,360 plus tax. In my mind reasonable for much better tires or nicer rims. In the end it all depends on if you like the Tesla rims and how you feel about the winters they are providing with the winter package. I personally don't like either rim or tire.
