Best Touch Screen Layout
Discussion in 'Model S' started by scottflys, Feb 23, 2017.
Tags:
  1. scottflys
    scottflys Member
    Argyle, TX
    So here is how my Touch Screen looks most days. Don't use the NAV that much and don't like the Rear Camera View, so found this App that is formatted to fit the Tesla Web Browser, in fact I found two different apps. The one I use most works well, however doesn't update as often as the other one, but it looks nicer. You can of course hit the refresh arrow on the web browser to refresh the location and weather manually.
    Anyway, just thought I'd share
  2. proxy
    proxy Member
    San Jose
    Cool. Will definitely check this out.
  3. Sco3putt
    Sco3putt Member
    Northern Jersey
    I would too if I knew the apps.
  4. scottflys
    scottflys Member
    Argyle, TX
    Here is the other one, it updates better but its not as pretty.
    qTesla
  5. AMPd
    AMPd Active Member
    Northern California
    I have my maps at the top because I like to see if the freeways I commute on are backed up and if I need to take a detour.
    The lower part I have the music like you
  6. davinci2017
    davinci2017 Member
    Milpitas, CA, USA
    I've been using Teslapage.com in drive mode with the central clock and weather to the right, will check out the other options mentioned
