Best USB or microsd for v9 dashcam?
lukex4
187
648
Montreal
I guess my question is, presumably could I just plug this card reader into one of the front USB ports, then insert a microSD card (for the dashcam) and insert a regular SD card (for music)? This sounds like it might work if Anker claims that the reader can support simultaneous read/write. And if it works, it's a cleaner solution that eliminates the need for splitters, hubs, etc. Has anyone tried this? Or have any general thoughts on this option?
I'm interested in the answer as well.. Would love to free 1 USB port and/or remove the need for a USB hub.
minsup23
96
27
Chicago, IL
My inside temps were 99 degrees today in the car with outside weather being in the low 80s. Noticed my USB card is dead. I figured it's from the heat. I'm in the midwest and it survived frigid temperatures. Anyone have any recommendations on a new USB drive?
hulk2k17
403
171
DFW Area
I ended up running a sandisk usb 3.0 microsd adapter + BlackVue 128 GB microsd card for teslacam. I still have the Samsung pro endurance in the 900s. I format both cards monthly and have been satisfied with the results thus far.
felixculpas
633
694
Ontario, Canada
I have a Samsung Endurance Pro on order as my Kingston 128Mb microSD died in a few short months of use...perhaps extreme colds did it in. Card was older but only used a handful of times prior.
hulk2k17
403
171
DFW Area
For continuous write applications like dash cams, you need a high endurance card for improved longevity : Samsung pro endurance, transcend high endurance, WD purple, there are others but these are the ones I’m aware of.
Edgewood Dome
218
113
Edgewood, WA
Just use a large capacity SSD USB drive, partition it into 2 drives, one for the TeslaCam, other for music, etc. The SSD is made for long term read & Write, plus the higher speed reduces or eliminates bad files from the repeater cameras and eliminates music stutter. They do cost upwards of $100, but I think we can all afford that.
eladts
661
808
Brookline, MA
Most USB SSD drives are not rated for extreme temperatures, as they are designed for home or office use. High endurance SD card are specifically designed to be used in dash cams so they can operate in a wider range of temperatures.
Edgewood Dome
218
113
Edgewood, WA
Good to know, thanks. I'm currently using a SanDisk Extreme Portable SSD, 1TB (lots of music). It has an operating temperature range of 0°C to 45°C which should be fine for the interior temp in most USA climates. Probably too low for some of the hot states if parked outside without the cabin overheat protection turned on. Also probably not good for the colder states if parked outside in the winter, but fine for Seattle where I live.
