Best USB stick for Dashcam?
Jack Tripper
130
162
What USB stick is recommended? I'm not sure on capacity or if it has to be USB 3 instead of USB 2. Looking for a nice price this weekend.
BluestarE3
4,084
5,158
Norcal
I got a Lexar Jumpdrive 64GB USB 3.0 stick from Office Depot a few days ago for $9.99. Don't know if it's the "best", but it seems to work fine partitioned for dashcam and music.
quickstrike12
620
461
Fort Worth Texas
That’s as good as any I’m sure. I went with an Amazon buy of a patriot 32GB USB. It’s a 2.0 since that’s all the car can read anyway. The patriot brand was rated as one with very fast read and write speeds. I was having all sorts of problems with generic regular USBs.
Long story short I haven’t had a single issue in over a month with this one.
Woodson
Attleboro, ma
I am having troubble installing the Dash CAm in my Model S 100d. Even after I reformated the my 128gb 3.0 flash drive, I can't seemed
to get the Icon to come up at the top of the screen. I formated it to FAT32 and still it does not come up, and there anyone the can give a remcomendation. Please help me out.
thanks
SMAlset
9,084
9,809
SF Bay Area
thanks
Did you set up the TeslaCam folder as specified? Case sensitive I think.
Jack Tripper
130
162
I bought a Samsung USB 3.0 64GB, but unfortunately it came formatted as exFAT. I read that isn't supported by TeslaCam. Any tips on changing that to FAT32 as required?
I tried the command line format, but received an error, "the volume is too big for FAT32."
djlott
130
146
Livermore, CA
Reviving this old thread....
Has anyone noticed a difference using a USB 3.0 (or 3.1)? I have a 32GB USB 2.0 Sandisk. It's okay but I often find that when I view the saved files, some of the saved files are good and others are not. Meaning, rough 20 to 30% of the files are 1kb, non recordings while others are just fine. I also found heavy pixelation on some of the pillar camera recordings when using Sentry mode. I don't know if that's just a limitation with the current DashCam / Sentry mode code or if other USB sticks might provide a better recording consistency.
I guess I'm asking if upgrading to a higher capacity (128 to 256 GB) USB 3.0/3.1 provides a better recording consistency, even though the car only supports USB 2.0.
Mark_T
1,292
1,129
UK
I've not done enough testing to be certain, but I'm suspecting that ability to handle continuous writes without overheating may be more important than USB2 vs 3.
I switched from a faster SanDisk Ultra FIT 64GB USB 3.1 to a slower High Endurance Sansung micro SD (in a suitable adapter) and the quality seems a lot better.
I do need to do more testing though as I've also had firmware updates that may have been the biggest factor.
Reactions: djlott
jvl007
71
13
SF Bay Area
Anyone have any issues with video distortion? I'm noticing left repeater videos are distorted and are green for the button half of the videos. Front and right repeater seem fine.
Not sure if it's related to USB?
BluestarE3
4,084
5,158
Norcal
Fairly common problem reported by quite a few people here, regardless of type of storage media used. More likely a software problem.
jvl007
71
13
SF Bay Area
Thanks. Glad this is a problem specific to my vehicle. Hopefully they can come out with a fix. It worked at first, but then the green started showing up on the left repeater recently.
