Best Utility trailer for MS?
Discussion in 'Model S' started by AndreyATC, Feb 6, 2016.
Tags:
  1. AndreyATC
    AndreyATC Member
    New City NY, USA
    #1 AndreyATC, Feb 6, 2016
    I need help choosing a trailer for personal use
    It will be used to transport some small motorized equipment (e.g. Golf cart, lawn mower etc)
    So ramp is a plus
    Will be used to bring some drywall, lumber and firewood
    anything house owner normally uses
    5x10 is the minimum size with 3000lb GW
    looking to spend about 2k
  2. imclurcan
    imclurcan Member
    UK
    Apologies if I have misunderstood your question but I have been told that the Model-S does not support a tow hitch. I was told this by my Tesla dealer.
  3. StaceyS
    StaceyS Member
    Bend, OR United States
    Years ago I bought a Snowbear 5x10 tilt-bed utility trailer from Home Depot for $600. Its worked out great.
  4. AndreyATC
    AndreyATC Member
    New City NY, USA
    I installed Torklift Ecohitch just like many members
    its class ll rated 2000lb
    I will also use the hitch for bikes
  5. AndreyATC
    AndreyATC Member
    New City NY, USA
    #6 AndreyATC, Feb 7, 2016
    Aluma looks great
    I've seen some mission trailers
    Aluminum Landscape & Utility Trailers by Mission Trailers - MU5x8WR
    they look very similar and priced about the same
    Many of them have ramps which is good but they don't fold flat when transported empty?
    I wonder if that's going to create an affect like I'm driving with parachute in the back
    better yet, what is the worse for range, pulling more weight or less weight with more drag?
  6. imclurcan
    imclurcan Member
    UK
    Thanks for this. It is clearly news to me and I am somewhat perturbed that Tesla gave me a straight "No" when I asked if I could fit a tow hitch!! Now I just have two questions: Does using this tow hitch invalidate any Tesla warranties? Can I get this hitch in the UK?
    Thanks.
  7. sorka
    sorka Well-Known Member
    Merced, CA
  8. AndreyATC
    AndreyATC Member
    New City NY, USA
  9. Quantum`
    Quantum` Member
    Seattle, WA
    Put 1,500 lbs on that ATC and you're at the very max for the hitch. You'll get to that weight surprisingly quick, and that's assuming the trailer has a brake. But it doesn't so forget it.
  10. unreliantrobin
    Antarctica, Antarctica
    In all honesty, I personally like the harbor freight trailers. I have used them in many instances, not with a Model S yet, but have worked great with my Subaru and Sprinter Van.
    Heavy Duty Utility Trailer - 870 Lb. Capacity
  11. Xenoilphobe
    Xenoilphobe Active Member
    Fairfax County, Virginia
    5x10 is the minimum size with 3000lb GW. The harbor freight trailer is 40 x 48 inches and 870 lbs or 1/3 of the OP's specification. Also it's steel vs Aluminum which will be heavy and will rust without a nice garage or cover.
  12. Xenoilphobe
    #14 Xenoilphobe, Feb 8, 2016
    I would try and get one that doesn't have that high tailgate, but one that will pivot down at the axle - this will help reduce drag and increase the range of the vehicle....http://www.alumaklm.com/item/95-6810t-utility-trailer.html
    ALUMA has a five year warranty and ATC only has a 3 year warranty.
  13. AndreyATC
    AndreyATC Member
    New City NY, USA
    Finally made the decision
    what do you all think?
  14. Xenoilphobe
    Thats sweet~ which one is it? How much? specs?
  15. AndreyATC
    AndreyATC Member
    New City NY, USA
    ATC 5x10 all aluminum
    15 inch wheels
    Removable ramp, which also folds flat on the bed
    dry weight is 470 pounds
    Got 320whm usage while towing empty at 60-65mph
    It's rated at 3000 pounds
    Meaning effective load is 2500
    So while my hitch is rated at 2000 I can still put 1500 of the load
    This is a bit pricey at $2100
  16. unnoho
    unnoho Member
    Pembroke Pines, Fl
    Yes the non-folding gate will have a big impact. I used to have a Chevrolet Cobalt Supercharged. I got on the highway pulling an empty 5x12 utility trailer. Normally the car was in vacuum about -5 but with the gate up it was boosting 7 psi. I was literally watching the gas gauge drop as I drove and it didnt help that I burned a mix of premium and E85 for performance but it also dropped economy about 15%. I pulled over after 5 miles on the highway and removed the gate to lay flat on trailer.
  17. Xenoilphobe
    #19 Xenoilphobe, Feb 21, 2016
    Looks great to me. I would pay that much for it if they removed the cheesy website sticker.. :wink:
  18. Evbwcaer
    Evbwcaer Member
    Minnesota
    Do your parking sensors detect/alert for the trailer or load?
