Best wireless charger?
I just got the Taptes as well. Its great. But follow the instructions! There isn't much so its easy to gloss over. Don't make the mistake I did and assume the USB splitters are just plain splitters. There is two different ends one is power only and one has data and power. This is important, if you connect the taptes to the data side you will mess up your USB ports which requires a reset.
Otherwise the charging is very convienent. The only thing that is a minor issue is you can raise up the lower shelf all the way anymore.
There is also a hidden usb c charging cable on the Taptes, I didn't notice this until later on...
Can someone give me an up-to-date recommendation on how to do this? A two-phone wireless charger that also lets me have a sentry-mode/dashcam driver attached? Thanks!
This is how I do mine. Very clean, no splitter hassle.
http://amazon.com/dp/B07PH2WXKT/
