Sounds like you have TeslaFi. I guess for each charging level, you will need to leave it charging for some amount of time. I guess I would get TeslaFi's data on how many kWh you add for each charging interval (you'll presumably need to interrupt the charge). But you do need to understand exactly what TeslaFi is reporting from the API (there may be multiple fields for the amount of energy - one for energy added to the battery, another for the power out of the AC-DC chargers - they won't be the same!). It's important to understand what the numbers TeslaFi reports mean.
I expect that the Breaker amps and the amps reported by the car should basically be the same. But you'll have better resolution on your breaker amps probably.
You should record the voltage that the car sees in a column. This is going to change depending on your current setting.
It would be interesting to see the exact overhead amps from your current clamp when the car is sitting there not charging (since it will have better resolution than the in-car display), but that 2A (that's what I observe it to be when the door is open and the screen is on - so 500W) does not last long before the Wall Connector opens its relay. You also have to record the voltage at that 2A to figure out the static power. It is good info to have, but I guess you just need to record it once.
I don't think you need to subtract that 2A or whatever from your numbers, though - it's part of the overhead you're trying to determine. And the number you see on initially plugging in probably is not the same when the car is just sitting there in idle mode with the display off and just charging (that seems to be closer to 200W, just based on the energy consumption of idle mode from other data).
There are a lot of other details I'm not covering here. You'll probably have to gather data and then iterate on the method as you discover the shortcomings of the approach.
Ideally you have measurement of the voltage at the current clamp location and at the Wall Connector input, too, but probably not realistic.
I do have TeslaFi but I'm just going to take readings at the breaker with the clamp and use what the car is reporting to make this quicker since I have about 20 sets of data to record. I'm hoping that it will just give me an idea on where it's most efficient. I'll make sure that it charts the gross and net loss so if people want to see one or the other (or both) the data will be there. I will be measuring the voltage at the car as well. I thought about the voltage at the breaker but I don't have a way to be safe with that one that will make it easy so I just left it off the dataset.
