Cars drag is mainly due to frontal cross sectional area (consider the biggest cross sectional area facing forwards) and the ability to 'reattach' the air at the back. Your ideal car (look at one of the solar cars that they race across Aus) is more like a wing. Gentle taper to the back and nothing sticking out to upset the smooth airflow. Reality is cars of that shape are not the most practical (too long and low). So commercial cars trade off and there is turbulent air at the back. Notice how the back of your boot round the number plate gets dirty sooner then other areas. Thats the dirt spun round in the turbulent chaotic flow at the back.
So a bike on the back doesn't help either of these. It increased your cross sectional area and has no taper behind it. I cant put it into numbers without a lot of number crunching and brushing up on my fluid dynamic skills but it will be ugly!
Now speed is important. In a high speed race car like a Le Mans racers the reattachment is probably more important then frontal area as the turbulent air will cause a significant vacuum at the back. Even at more reasonable speeds the effect rises with a square of speed. So at 60mph drag is 2.25 as bad as at 40mph. 70mph 3x as bad as 40mph. So best to slow down and have a more chilled drive if you dont want to suck the range of your electric car down.
Actually thinking about it, its worse then that. Force is a square of speed, but power is a cube of speed!
