Bike Racks or Hitch Rack/System Ideas for MS
Discussion in 'Model S' started by Tribaltech, Jun 18, 2017.
  1. Tribaltech
    Tribaltech Member
    Michigan
    Hi everyone,
    I am curious as to what bike racks do folks highly recommend for use with the Model S? Please let me know the brand name and model number for a 2 or more bike rack that worked well for you.
    Currently I have a Thule Bike Rack but its getting old and I am wondering if there are newer ones that some of you on here have had a good experience with. Also, specifically if it is a trunk mounted type does it works well and install easily on the Model S considering its hatch-back-y shape?
    Alternatively I would love to understand if someone has had experience with getting hitch bike racks installed on their Model S. If yes please provide some details on how you installed the hitch or where you had it installed and the bike rack that works well with that system. i am actually leaning toward a hitch bike rack system and would really appreciate some guidance in that regard
    Thank you very much in advance.
  2. skitown
    skitown Supporting Member
    Central Idaho, U.S.A, Earth
  3. ReddyLeaf
    ReddyLeaf Member
    Pasco, WA
    I had TorkLift Central install mine as well. Works great with a 4 spot Yakima rack. Be advised that increased wind resistance can drop range 25-50%.
  4. Xenoilphobe
    Xenoilphobe Active Member
    Fairfax County Virginia
    I have had the torklift hitch installed in all three of our Model S's. I use the
    I have carried my zero fx, my Trek Madone 6.7 SSL and my Pedego Electric bikes on this hitch. I can carry four 50 lb bikes.
  5. Xenoilphobe
    Also check this out:
  6. Tribaltech
    Tribaltech Member
    Michigan
    This is super helpful!! Thank you very much. Just curious where did you get this installed? Just a local body shop or anyone special who handles this kind of stuff? In either case did you feel confident that they weren't going to cut open the underside of your Tesla or the bumper? I will purchase this but I want to be sure I am taking this to the right people to do the installation. Do you feel that the "Service King" folks that Tesla recommends are capable and knowledgeable about this? Thanks again
  7. Tribaltech
    Tribaltech Member
    Michigan
    Thanks so much. When you mention range drop, I am assuming you're talking about when you are lugging the bikes around on the rack, correct? Not when the rack and the bikes are off, right?
  8. Tribaltech
    Tribaltech Member
    Michigan
    Sorry one more question. What is the difference between a 1.25" hitch receiver vs. 2". Are there advantages to the 2" one? Thanks
  9. Xenoilphobe
    U Haul installed mynlast one. I showed them the online install video and let the installer use my iPad to do the install. I did the first one. Not too hard.
  10. rypalmer
    rypalmer Active Member
    Canada
    I have the ecohitch, and I bought a Thule T2 Pro XT. It's a brute, but very solid solution for 2 bikes and easy to use. It's still easy to back into Superchargers with the rack folded up, but folded down its tricky. Pull-in spots are fine of course.
  11. Lee_B
    Lee_B Supporting Member
    Springfield VA
    Hey I ride. If ur looking for a bike rack go look at seasucker.com. they are the best!!
  12. ReddyLeaf
    ReddyLeaf Member
    Pasco, WA
    Yes, I remove the entire rack and angle bolt (steep driveway won't allow even an extra 2") when not in use. The rack without bikes will also affect range, maybe 10-30% (everything will be speed dependent). Also, be advised that visibility is greatly reduced out the back window and backup camera. Moreover, constant beep warning when backing and difficulty supercharging (Tesla was stupidly kind enough to place the parking signs right in the center between the SC pedestals, which you can just barely straddle with two bikes, but not four.).
  13. Lee_B
    Springfield VA
    This is the seasucker.
  14. Xenoilphobe
    You can turn off the beeps (I keep them off all the time anyway) - and yes Tesla did perfectly center the signs which means you will have to angle your way in - on the east coast it doesn't matter - our superchargers aren't that busy - yet one the 3 comes out - we are probably going to have some crowding.
  15. Lee_B
    Springfield VA
    Xenoil, On a side note where are you riding? I have been doing the W&O in Shirlington or taking the trail through National into DC because I cant (dont know of) good trails in Fairfax proper. What trails do you recommend. This is my 2nd year riding so I was looking for other places to go
  16. rypalmer
    Canada
    I haven't figured out how to turn off the parking chimes. Could you please share how you disabled this warning?
  17. skitown
    I had Torklift in Kent, WA install it. I figured they were as good as I could ask for since they engineered the thing and I picked up my first car in Seattle anyway. However, I'm getting another Model S in a couple days (yay!) and I haven't figured out where to have this one installed as Kent, WA is a long way from where I live and there are no certified installers anywhere near me either. Nor Tesla body shops. Since I'm in Idaho most people haven't even seen a Tesla, let alone worked on one, so I'm still figuring out what to do. I may use a seasucker in the meantime as I have a friend with one.
    As for racks - I've used Thule T2s, and Kuats, but purchased a 1upusa rack actually as a 2 bike version can fit folded up IN THE TRUNKWELL. Sorry about caps, but I studied the heck out of this and it's super cool that it actually fits. Even easier if you disassemble into two pieces. Note I can only vouche for the regular ones - vs the "heavy duty" version which may be a tad bigger, not sure.
  18. skitown
    Xenoilphobe - I maybe have myself psyched out about the job. Glad to hear you had a good experience with Uhaul. Presume your Tesla was their first?
  19. Tribaltech
    Tribaltech Member
    Michigan
    So I have been researching the Torklift EcoHitch and it looks like a great solution but here's a follow up question:
    In some of the installation videos I saw that the installer had to cut out an oval shaped hole in the underside of the Model S. And then some folks recommended that Torklift also sells what they call an "Undercover" to cover up that hole when the hitch system is not in use. Now my problem is that I visit dirt roads quite often and having that "undercover" thing would be a must for me. But Torklift website says that that undercover is meant for only the 2012-2015 Model S. And my car is a 2016 Model S. So my question is that
    1) What year Model S do you have?
    2) If someone here has a 2016 Model S then how does one cover that hole?
    Please let me know. Thank you very much.
  20. skitown
    My installation was on a 2013. I had a convo with the guy at Torklift that designed the cover. He lamented that some folks complained that it wasn't a perfect seal. It's not. I would call them and see if they have plans to make one for a 2016/17 and/or what the deal is. They are a small outfit. I have a hard time imagining them not being able to make one if there was demand; perhaps they've not had a newer model locally want one for them to fab up a new design. Seems like the old cover could maybe even be modified by a local machine/welding shop in your area to make it work. Regardless, I'm not sure I'd let the lack of a cover stop me from getting an Ecohitch.
