I have used spacers to bring the wheels out flush with the outer fender.
Do you have a link to the brand and model spacer you used?
Also, does it kick alot more debris onto the side the of vehicle?
What is the offset of the arachnids? Staggered fitment or same all round?
40 offset, standard for Tesla wheels, and same all around.
Incorrect, the Arachnid wheels are a staggered set, 8.5" Front, 9" Rear
21″ Arachnid Wheel
Size: 21X8.5″ front, 21X9.0″ rear
Offset: +40 front, +40 rear
PCD: 5X120
Center Bore: 64.1mm
Weight: 21×8.5″ = ~26.6 lbs. (without tire), 21×9.0″ = ~28.5 lbs. (without tire)
The front wheels are 51.8 lbs., while the rear wheels are 53.9 lbs. with tires
Wheels are 8.6 lbs. lighter in front and 9.5 lbs. in rear wheel for a total reduction of 36.2 lbs.
of unsprung weight compare to the 21" Turbine wheels (which are $6,000 in the Tesla Store).
Lug Nut Spec: 13/16 Hex, 14X1.50 Thread
Lug Nut Torque Spec: 129 lb-ft.
Price: $ 7,600.00
Details: This wheel is not available when ordering a Tesla Model S.
Any idea guys?Excellent thank you! I’d this the same as the 21” staggered turbines?
Do you notice any difference in steering / handling with the spacers? They sure make it look nice...
Good stuff. Can you take some more pics from a bit farther away so we can see the whole car and get a better feel for the work the spacers are doing for you.
ArmorTech Powder Coating, Inc
954-979-8600
www.armortechpowdercoating.com
Will do but will take the photos tomorrow am. The car was not finished until late today.
The caps are real carbon fiber. The chrome was wrapped today in Vvivid gloss carbon fiber along with the handles. Pictures tomorrow, but I can say now it's a fantastic wrapping job.
Motorsport Technology. Spacers are 30mm front 20mm rear. But this could vary by several mm depending on the section width of the tires you have and how flush you want them with the upper fender edges.
He was answering about offsets.Incorrect, the Arachnid wheels are a staggered set, 8.5" Front, 9" Rear
@artsci Wheels and chrome delete looking great. I like the head-lights, can you share the cost and how long it took to get them done. Thanks.
Ok I’ve ordered 4x 15mm spacers based on this
Size of wheel spacers on staggered turbines?
Where hbey5 has gone with 18mm, ideally I’d like them slightly further inward so I’ll see if they fit
Make sure you post pictures when you get them installed. I'm thinking about going with 15mm as well.
