Blacking Out Chrome moldings
Discussion in 'Model S: Interior & Exterior' started by BMWXX55, May 18, 2016.
  1. BMWXX55
    BMWXX55 Member
    Berkeley CA
    Hi everyone I am a soon to be tesla owner. I have placed my order and I am looking at a late May early June delivery. The only thing I don't like about my tesla is the amount of chrome it has on it. I am coming from a BMW 435i M sport which came from the factory with no chrome which I loved. I am curious if any of you guys/gals have any experience with wrapping or painting the chrome molding's? And if anyone has done this how do they recommend it? Is it holding up? Also if anyone who has done this could tell me how much they paid that would be great also. Thanks everyone the wait it killing me :)
  2. pdxrunr
    pdxrunr Member
    Lake Oswego, OR
    Model S Photo Gallery
    See post 663 with my pearl white MS. I had mine done just last week. Cant speak to a long time frame, but good so far after one wash. They recommend hand wash or touchless only. The only hard part are the mirrors, everything else is easy. Expect to pay $1k to $1,800 to do all the chrome on the car. I went with the 3m 1080 product, but Avery is good as well. I am very pleased how it turned out and changed the attitude of the car in just the right way.
  3. Tech_Guy
    Tech_Guy ALWAYS IN LUDICROUS MODE! P90D>P100D Upgrade
    Los Angeles
    Im in the same boat as you just placed my order and plan to black out the chrome as well as wrap the whole car with a paint protective film from 3m. The shop quoted me 500 to wrap all chrome on the car to black but hey haven't seen a refreshed car so id suspect the price could change up or down depending... For example the older cars had chrome on the rear diffuser but the new ones don't... I might be getting a better price because I'm already wrapping the whole car with them... Also called a few other shops one wanted to paint all the chrome and wanted 1500 for that vs the wrap.
  4. benjiejr
    benjiejr Technogeekextraordinaire
    San Antonio, Texas
    I had a friend who does it for a living, dechrome my Model S in satin black in July 2015. I helped him some and I saw how much work was involved to do it right. Wrapping the chrome around the mirrors was especially challenging just because of all the curves and moving parts. I'm happy to say it's holding up very well 10 months later! I paid around $1000.
  5. Bulletproof
    Bulletproof Vendor
    Hawthorne, CA adjacent to the Supercharger & Desig
    We offer chrome delete services. It's a time consuming and meticulous process to do correctly but once done it holds up well if quality materials are used. In our case we offer a one year warranty on the work and the vinyl used comes with it's own warranty as well
    IMG_4984_BE.jpg 2015-11-24 17.14.57resized.jpg 2015-11-24 17.30.57resized.jpg
  6. anxman
    anxman Member
    san francisco, ca
    I had my vinyl wrap done by Vinyl Styles in Belmont, CA. They've done work for me twice and they're awesome. My chrome wrap is still holding up 25,000 miles later.
    My rashed out powder coated wheels on the other hand ...
  7. sickfox
    sickfox Member
    San Francisco
  8. BMWXX55
    BMWXX55 Member
    Berkeley CA
    Thanks everyone for the responses I will defiantly call the place in Belmont and see how much they will charge.
  9. BMWXX55
    BMWXX55 Member
    Berkeley CA
    How much do you guys charge for wrapping the chrome on the tesla? Also if you do protective clear bra's I would also be interested in that as well.
  10. Ingineer
    Ingineer Electrical Engineer
    What did they charge you?
  11. SDRick
    SDRick Active Member
    SD CA United States
    How difficult is it to wrap vinyl? Is it DIY?
  12. Edmond
    Edmond Permanon
    Seattle
    #12 Edmond, May 23, 2016
    I suggest Youtube University if you're fairly handy. There are two kinds of wraps, 'wet apply' (Xpel, Suntek, et al) and 'dry apply' (most newer opaque wraps). Dry is a little more challenging and you should have at least two people to lay the wrap, although there are tricks like 'hinging' it. (peel off a little on one side to stick, then peel from the other side) It's still unstick-repositionable. Heat gun to conform, doing as little stretching as possible. Plastic squeegee (ideally with felt edge) to fasten, then for 'dry apply', heat hot to bond. Best to remove the parts you want to wrap if they're practically removable. For wet and dry, allow a week to bond before waxing.
    The fast-and-dirty shops use templates of your car to cut out the shapes of pieces from a bulk roll. (and it costs them alot to use the templates) These are easy, but do not wrap around edges and may come dislodged over time (car washes), so I prefer cutting larger pieces out of bulk rolls to custom cut and wrap around edges. And wrapped edges should be primed with 3M tape primer for far better stiction.
    Problems are: particles ending up under the wrap causing bumps (or white spots for transparent), which is why hinging is a good method to reduce that. Clay wipe (there are clay wipes - auto body supply) the whole surface right before application.
    Surface chips or deeper scratches will show through any wrap, so polishing (with a random-orbital) is a good idea. For transparent wrap any surface flaws (swirls) will be enhanced, so once again polish and use a single-source light to find swirls, especially on darker colors. Key to polishing is to keep the pad clean. I use a microfiber cover over the pad and change it when it gets dirty; or if you have an air gun you might be able to blow off the pad.
    (he's pretty proud of his toy, but ignore that)
    To apply wet-apply you use two spray bottles:
    - Tack (adhesive side): 15% of 70% isopropyl alcohol
    - Slip (outside): 2-4 drops of johnsons baby shampoo
    What brand of wrap is the next question. 3M has a rather bad reputation for quality on wrapper's forums, which came as quite a surprise to me. So I bought Xpel and Avery. Brushed metal wraps (like my Brushed Steel) only have a lifetime of a couple years, so I'll be applying Opticoat Pro+ to it to make it last, if I can find someone who will sell it to me. "Opticoat Gloss" is the consumer version, but it only lasts a couple years, and dealers are prohibited from selling Pro+ to civilians, for cartel reasons.
    And that's all their secrets.
  13. SDRick
    SD CA United States
    Very informative, thanks for sharing the knowledge. With a touch of humor sprinkled in as well. Very nice!
  14. benjiejr
    San Antonio, Texas
    IMHO, I definitely wouldn't call it a DIY job for most people. Experience and technique certainly play a big part in how it is applied. How the edges are handled make a big difference in how well it will hold up over time. That being said, if one had the time, patience, and money to redo panels several times then I think it would be something some people could take on as a project.
  15. anxman
    anxman Member
    san francisco, ca
    It's been a while but I think it was around $500 for all four wheels including the dismounting and remounting.
  16. James Anders
    James Anders Member
    Southampton, PA
    Shame Tesla doesn't offer a black exterior trim option.
  17. Terra117
    Terra117 Member
    Edina, MN
    Wrapping the trim can be a DIY job, if you are handy and a quick learner.
    My first experience with wrap was wrapping my P85D trim. I watched several online videos and started slowly with the simple stuff (the straight trim pieces).
    I decided two pieces needed to be redone, but am very pleased with the results.
    First warning: the chrome around the mirrors and door handles are very difficult. I plan to redo the chrome on the mirrors when I get my LH sound system and have the doors taken apart. The mirrors really need to be disassembled to get a professional quality job.
    Second warning: there are lots of tools needed that will significantly drive up the cost if you don't already own them. I needed to purchase squeegees, knifeless tape, adhesion promoter, edge sealer, and wrapping gloves. I already had a high end break-away knife, heat gun, IR temp gun, nylon trim removal tools, assorted nylon picks (similar to dental or clay sculpting tools) and probably a few other things I'm not remembering off the top of my head.
    It is very understandable why people take their cars to a pro to get dechromed, especially if they have jobs.
    Final warning: If you do it yourself, and it turns out well, expect to get lots of requests to help friends dechrome their cars.
  18. Edmond
    Edmond Permanon
    Seattle
    Need to remove the door handles and mirrors whether you're doing chrome delete or wrapping the door panels. I think it's important to wrap around the edges.
    I don't see any need for knifeless tape; no cutting should be done on surface areas. Precut and dry fit if you have a special pattern.
  19. BMWXX55
    BMWXX55 Member
    Berkeley CA
    Agree I would totally get the option if it were one
  20. nagerseth
    nagerseth Tesla Enthusiast/Owner
    Washington, DC
    Those are some nice chrome deletes...
    I've done it myself, using PlastiDip. It was A LOT CHEAPER, around a couple hundred bucks, and it's clean as hell. 3rd time I've done it this time actually, first was orange (did the whole car orange), then matte black, and now white. It's beautiful, and would definitely recommend it.
