RobertSeattle
i hope Tesla just allows this to be an option in the 3.... I'd pay $1000 for a built-in camera system.
The front camera in the X is not as good of resolution as the Blackvuei hope Tesla just allows this to be an option in the 3.... I'd pay $1000 for a built-in camera system.
Understand - I just want the option to a totally separate from autopilot cams camera system.The front camera in the X is not as good of resolution as the Blackvue
Perfect video - was just about to look at doing this. One question - one of the installers I spoke to mentioned that they run the front-to-back cable in an existing channel that exists in the middle top of the car ceiling from front to back (i.e. in between the top of the FWDs). Did you ever look at that, or does anyone else have any experience in trying to fish a wire through there?
Oh, and had anyone else purchased an OEM channel from Tesla? I was told by someone else that they won't sell them ....
I'm assuming that your first question was with regards to running a single rear-camera cable from the start of the headliner to the rear. If that's what you're asking, I briefly considered this option and even used a schematic I found of the headliner. I quickly determined it would be much easier to work around the trim inside the opening of the fwd. Blackvue gives you plenty of cable to go this route.Perfect video - was just about to look at doing this. One question - one of the installers I spoke to mentioned that they run the front-to-back cable in an existing channel that exists in the middle top of the car ceiling from front to back (i.e. in between the top of the FWDs). Did you ever look at that, or does anyone else have any experience in trying to fish a wire through there?
Sometime back there was a post from a vendor @First Impression that makes the channel and ships them for $175. From the pictures it seemed like an exact replica of the OEM channel.I'm assuming that your first question was with regards to running a single rear-camera cable from the start of the headliner to the rear. If that's what you're asking, I briefly considered this option and even used a schematic I found of the headliner. I quickly determined it would be much easier to work around the trim inside the opening of the fwd. Blackvue gives you plenty of cable to go this route.
I'm still trying to purchase an OEM channel from Tesla, and will see what the status is next week when I drop off my vehicle. If that doesn't work, I may use a cable channel (spray-painted charcoal) as described by OP. If I feel adventurous, I may remove the OEM channel and stuff it in there. At the moment, I have the two wires taped to the OEM channel (not too pretty).
If you want to use the OEM channel, I highly recommend getting it from Tesla Service directly. It's a third of the cost.Sometime back there was a post from a vendor @First Impression that makes the channel and ships them for $175. From the pictures it seemed like an exact replica of the OEM channel.
@plasmo Unfortunately, I didn't take video of the power wiring since it would have been pretty difficult to film. Also, after I did it, I came to the conclusion that I would have preferred wiring it up to an OBD2 Memory Saver. It would be a lot easier to splice to an OBD2 Memory Saver since you wouldn't be working with a short segment of wire by the kick plate. You could either splice a cigarette adapter onto the OBD2 Memory Saver, or you could splice the Blackvue power cable directly to the OBD2 Memory Saver. Either option could be done away from the vehicle which would make for much easier working conditions. And the OBD2 Memory Saver just plugs right into the OBD2 port under the dash.
I was considering it, until I realized that the drain on the Model-X battery was going to be insignificant compared to the existing vampire drain. I concluded that having this extra pack wasn't going to really make a difference. It would be the equivalent of adding a couple of more cells into Tesla's pack that already contains ~7,500 cells. That's a .03% increase.thanks. Even though there is more bulk and expense, I am thinking of possibily using Blackvue's Power magic battery pack (B-112). I wonder if anyone here has used the B-112 in the Tesla X.
yes, mine is leased, so this is one of the reasons...If your X is leased it is not a bad idea
Make sure you get the blackvue battery: BlackVue B-112 Power Magic Battery Pack
No need for the PowerMagic--only for ICE cars where the 12v will get discharged and then the car won't start. When the Tesla 12v gets low it is topped up by the DC-to-DC system from the main traction pack.
