blackvue DR650GW-2CH 12v quick power routing
Discussion in 'Model S: Interior & Exterior' started by Xenius, May 18, 2017.
  1. Xenius
    Xenius Member
    Havertown, PA
    Hey folks, I recently had to replace my front windshield and had a lazily set up blackvue on it. Originally I literally just had the power cable hanging down wrapped around my slimline phone mount and then routed directly to the 12v cigarette adapter plug.
    For now I'm fine with just using the 12v plug as I currently don't have the camera running at all, so something is better than nothing! Do any of you with an AP1 or earlier Model S use the included cigarette adapter and if so, how did you route the power cable? I found one video on youtube that described routing the cable around the right front headliner, then behind the weather stripping of the door, and then under the glovebox and into the center console. Wondering if anyone else had done this and if the standard plug/cable was long enough or I need to pick up something like Amazon.com: Blackvue Car Blackbox Power 15ft Hard Wiring Power Cable for DR500GW-HD, DR550GW-2CH, DR600GW-HD, DR650GW-2CH, DR650S-2CH, DR650S-1CH, DR430-2CH, DR450-1CH, DR470-2CH: Car Electronics
    Cheers.
  2. BrettS
    BrettS Member
    Orlando, FL
    There should be an always on wire in the microphone grille in the headliner right above the mirror. When I installed my dr650 I just cut off all but 10 or 12" of the cigarette lighter cable and ran it up and connected it to power there. There are a number of posts on here with pictures to show you how to find it and connect to it.
  3. MorrisonHiker
    MorrisonHiker S 100D 2019.16.2
    Colorado
    Jump to about 8:30 to see how to wire it in to the power cable behind the microphone grille.
  4. Xenius
    Xenius Member
    Havertown, PA
    Sweet thanks guys, this should work, put in an amazon order for the parts. Hopefully I'll remember to come back and post once done.
