I just installed (or tried to) a Blackvue DR650S. (It's laying loose in the car.)
Don't seem to understand it.
I though it would do this:
Work just like a Nest cam, record to SD when you drive ... then when you get home to the garage and it recognizes its home wifi network, attach to that and transfer video from SD (if you want to) to the cloud, to your account.
Instead what it seems to do is turn wifi off and on when it feels like it, (can't figure out then) and you have to manually log into its wifi hub everytime, provided wifi is enabled on it AND you're close enough.
So I go to call tech support and there is none unless you want to call ... where is it .. somewhere in the orient. Like WTH?
So unless someone can extoll its virtues in the next day it's going back.
Am I missing something?
