Blanding SC direct to Holbrook SC - has anyone done this in S85? Any range anxiety?
Discussion in 'Mountain/Southwest' started by iCAR, Jul 18, 2015.
  1. iCAR
    iCAR Member
    Park City, UT
    #1 iCAR, Jul 18, 2015
    I will be driving back to Phoenix from a trip to Ft Collins next month and would like to return thru Moab and Blanding to the Holbrook SC. Anyone make this trip without going thru Gallup?
  2. MyJoule
    MyJoule Member
    Tucson, Az
    EVtripplaner.com says 224miles and 205 range miles between Blanding and Holbrook- at 70F no wind... Watch your speed, especially if there are strong headwinds and you'll make it after a range charge in Blanding.
    I'd start the trip at 5 under the speed limit and enjoy the scenery. once you are pretty sure you'll make it you can speed up.
  3. tcbailey239
    tcbailey239 Member
    Gilbert, AZ
    This is an old post but...did you make it?
  4. iCAR
    iCAR Member
    Park City, UT
    I did, but can’t remember the details. It’s mostly reservation land, so speed limit of 60 or 65 saving energy.
  5. tmoz
    tmoz S85D, Prius PiP
    Gilbert, Arizona
    We did Flagstaff to Blanding - 243 miles which is a little bit longer than Holbrook to Blanding. 2015 S85D.
    Needed to go slow for a bit. Yes, some range anxiety, but made it. Hotel in Tuba city has a 240 destination charger if you want to kill some time and get more juice, but it is just faster to go a little slower - 65 mph.
    Kayenta would really be a welcome addition in that area.
  6. Moabion
    Moabion Member
    Moab, UT
    I wonder how the reverse of that trip, Blanding to Flagstaff would work since I'd be gaining elevation? I'm also in a 2015 S 85D. Seems my first 30 miles go by awfully quickly as well. I suspect battery degradation?
  7. BrokerDon
    BrokerDon Active Member
    Newport Coast, CA
    We drove 200 actual road miles from the Page AZ Supercharger to the Blanding UT Supercharger through Monument Valley in our 2015 P85D with 19" Michelin MXM tires last March. Arrived at Blanding SC at ~ 23% SoC driving very conservatively the first 100 miles then gradually going faster as we approached Page. Not a problem since the scenery was beautiful, there was very little wind, and ambient air was cool / mild so no heavy AC or heat required. We had an "emergency" 14-50 outlet available with 50A / 240V at Goulding's Resort RV & Campground about 2/3rd's the way in Monument Valley which really negated any "range anxiety" since this route is in an otherwise EV charger "desert".
    Great planning = Great result. EVTripPlanner.com was awesome. ABetterRoutePlanner app might be even better.
  8. PLUS EV
    PLUS EV Running on Empty
    Seattle
    That's a high degree of difficulty leg in an S85. You'd better have a Plan B and Plan C. Good luck!
