Bleach on UW seats?
Plan B
4,843
2,217
Portland OR
Do not use bleach. Call your local SC and ask them who they use to fix seats....or search for a leather repair company. (yes I know the seats are not leather).
DarkMatter
1,126
870
Olympia, WA
The manual specifies clearly: water, then rubbing alcohol if that doesn't work.
Rubbing alcohol works great. I've used it to take off blue jean transfer. Get some alcohol prep pads and keep them in the glove box and you'll always be ready to clean up.
Reactions: Nerdy_Engineer
dragonxt
627
376
Bay Area
Rubbing alcohol. Read the manual dude.
Tried it, didn't work. Probably going to a leather repair place as suggested.
DarkMatter
1,126
870
Olympia, WA
You can even get 94% often. If that didn't work I might also take one quick stop at a tiny bit of non-oil makeup remover. A makeup remover wipe might work for that. If you're considering repair anyway a tiny scuff at next to zero cost might be better.
Good luck with it.
Xminus6
697
470
Bay Area, CA
Mr. Clean magic eraser is good on seats. I used it to successfully remove pen ink from our Gray leather seats on our previous Model S. I haven’t tried it on the UW seats yet but I suspect it would be pretty successful as well.
ABC2D
996
1,061
Home
I would stay away from bleach - it might be Ok for the ultra fabric/leather, but who knows how stitching thread would take it
vijf
New Member
Jan 6, 2018
Belgium
One thing that works like magic for pen ink on leather: try using hair spray. You'll see the ink become fluid again within a second, then you can wipe it all away.
