Problem:
I had this amber light blinking and the message :
Your car is charging at a reduced current (AC charging only).. It was coming up to 17mi/hr.
I had some difficulty while pushing the charging plug and I pushed it hard as suggested.(Some times not pushing enough is suggested as cause)
Root Cause:
The black top of the right charging pin was broken and remained inside the charging port. so this black piece got stuck inside. I had to use a nose pliers to pull this piece out.
Suggestion:
Tesla should make sure this does not break this easily. User should get a warning if some thing breaks in charge port.
Root Cause:
Suggestion:
