  • The final cut of TMC Podcast #27 is available now with topics time-stamped. We discussed: Consolidation in LiDAR manufacturers; Volvo EX90 shipping with LiDAR; FSD Beta Full Release in N.A.; FSD detecting autopilot cheats, Gwen Shotwell directly overseeing SpaceX Starship; and more. You can watch it now on YouTube. We should have it published to podcast networks shortly.
Blinking Red LED on my wall connector
Here's what it looks like:
Charging still works. The green lights move like they normally do but with the slow red LED blinking at the same time.
I checked the wall connector installation manual and the closest matching troubleshooting symptom is the one about overtemperature. That's not the problem (everything was cool).
I reset the wall connector and the red LED went away, but I know the way these things work. It'll come back again some day, only worse...
Any ideas??
doghousePVD
My grandfather’s car
Dec 3, 2018
697
641
New England, USA
I had a blinking red when first installed. The rotator switch inside was set to the wrong setting.
I think the Wall charger is very sensitive to having a good ground. Check to make sure the ground is well secured inside the wall unit. Also, many older houses have very poor grounding systems. Confirm that it is well connected (not loose) and the grounding rounds go deep in the earth, etc.
Mine did the same thing yesterday.
I can't remember if it was flashing read before I attempted to charge my Model 3 but I noticed it when it wouldn't charge. Powering off and on fixed it.
The wall charger was only installed on Thursday and it was only my second charging from it. I'lll have to see if it happens again.
user212_nr
1,407
884
US
One blink red is a ground fault.
If there is no water, it sounds like there could be a problem (defect) in the unit.
https://www.tesla.com/sites/default...ng/Gen3_WallConnector_Installation_Manual.pdf
