Blinking TPMS light at startup
Discussion in 'Model S: User Interface' started by Gig103, Jul 7, 2017.
  1. Gig103
    Gig103 Member
    Phoenix Metro Area
    It used to be that all the indicators were a solid light when I turned the car on. Now the TPMS light blinks. Tire pressures are fine and I just noticed the behavior today, a few days after the 17.26.17 update.
    Is this a problem? Or a change.
    I made a video:
  2. thecloud
    thecloud As rhythm raced inside, the ship came alive
    Sunnyvale, CA
    I noticed the same thing after updating to 17.26.17. It seems to be a new behavior, but I think it's nothing to worry about.
    All the so-called "idiot lights" come on at startup as systems are checked, then they go out after a few seconds. The TPMS light is no different, except when it's on, it blinks (as does the seatbelt indicator). If it stayed on, then I'd think it was telling me the air pressure was low, but in your video, it goes out before the airbag indicator does.
  3. Braxus
    Braxus Member
    SF Bay Area, CA
    Noticed this as well. Thought it was low pressure but even after ensuring all tires at 45psi, it doesn't go away. Read the manual and the only thing I can see is if it blinks for one minute, the TPMS sensor has failed. No info on the momentary blinking.
  4. Romand
    Romand Member
    Chicago
    Mine does the same
  5. MMinehan
    MMinehan Member
    Auckland, New Zealand
  6. David29
    David29 Supporting Member
    DEDHAM, MA
    Glad you posted this. I had seen the icon flashing as ell, and I just thought that it always had and I had not noticed it or had forgotten. I also just got 17.26.17 a few days ago.
  7. Gig103
    Gig103 Member
    Phoenix Metro Area
    Thanks for confirming it's new design. My car is CPO and has 50k miles I thought it might have indicated a low battery or something in the sensor itself.
    I watched my own video again and noticed that the blinking stops when the tire pressures are updated for the first time, so it's sort of like an "operation in progress".
  8. Dithermaster
    Dithermaster Member
    Madison, WI
    Thanks for confirming this was a software update. When I saw mine blink my first thought was that a tire was starting to get low, but then I remembered I just did a software update, so I chalked it up to that. I'm glad that's what it was, and not a bad tire.
