Bluetooth Audio Weak
Discussion in 'Model S: User Interface' started by RobinF, Jul 15, 2015.
  1. RobinF
    RobinF Member
    Houston, TX
    When I pair the iPhone to the car and play music I have to amp the hell out of the signal to hear it. Like setting to 7 just to hear it at all! I hope there's some way to address this.
  2. sorka
    sorka Well-Known Member
    Merced, CA
    Is the volume up all the way on your iPhone? I haven't noticed my iPod or Android devices having lower audio output than the same files played from USB.
  3. RobinF
    RobinF Member
    Houston, TX
    Not up all the way but pretty high.
  4. mwulff
    mwulff Member
    Danmark
    Normally this is related to volume on the phone. Just crank that up all the way (and turn down the car stereo)
  5. rickgt
    rickgt Enthusiast owner/member
    Carmel
    Unfortunately, the volume on the phone must be up... no matter how loud you make the system, it's limited by the phone's volume setting
  6. RobinF
    RobinF Member
    Houston, TX
    Interesting. I'm obviously a novice at this but that sounds counter-intuitive.
    Thanks!
  7. GaryREM
    GaryREM Member
    Fairfax, VA
    Not really.
    When operating on Bluetooth, the phone (iPhone)keeps a separate setting for Bluetooth volume. Why? So you can control the volume from your phone if you have remote speakers for example. Since you have easy control of the cars volume from your steering wheel, you want to connect with Bluetooth, turn the phone volume all the way up (that will set the Bluetooth volume not the phone volume with an iPhone, not sure on Android). You can then adjust the listening volume in the car with its controls.
