bluetooth/iphone problem - any ideas?
David.85D
1,348
1,120
I am the new owner of a CPO 2015 85D. The first couple of days I didn't have this problem, but now I get a weird problem every time I get in the car. The car thinks my iphone 6 is making a call (which means it mutes the radio and brings up the call screen) yet won't let me disconnect through the car interface. The car display shows a call in progress to "My Number", but doesn't let me end the call. The iphone itself shows no call in progress.
If I turn bluetooth off from either end (car or phone), the radio goes back to playing normally and all is well, except I have lost phone access.
Any ideas? Think this needs to go in for service?
hawaii118
New Member
Nov 19, 2016
Germany
Hi David, since 8.0 I have the same issue using an iPhone 6 plus. But rest assured it doesn't have to do with your Tesla because I have got the same problem in our BMW. I think it's an iOS issue.
Short work around: start a phone call from the centercreen and immediately break the dial-up.
Reactions: gastowatts
simonog
433
61
United Kingdom
@david: we used to see this issues, though not for some months.
Ensure your iPhone is running the very latest iOS. If it is, talk to the Service Centre through whom you bought the car to ensure that you have the latest car software. They can arrange a remote download if you haven't.
I'd be pretty sure it's one of the two, and it would be helpful if you let the forum know which update cleared the error. Good luck!
David.85D
1,348
1,120
Thanks! Tried your suggestion and it worked. Slightly modified... I was not able to initiate a new call from the center console, so I couldn't do exactly as you said, but once the car was confused, I started a new call from my iphone and then ended that call on the iphone. That seemed to allow the car to reset. So far I have been in and out of the car about 5 times and the issue has not come back.
EK123
12
5
Reno, NV
I bet you have an iPhone 7. . ..
Since iOS 10 and an iphone 7 I've had bluetooth problems including intermittent connection loss, phantom calls and the recent call list not updating. Bluetooth from the phone with some other devices don't work properly. Been waiting on an apple update. 10.1.1 currently...
I think it's apples issue.
David.85D
1,348
1,120
I have an iphone 6. I keep it up to date. It is currently on iOS 10.1.1. The car is on v8.0 (2.44.130).
Initiating and ending the call from the phone seems to have done the trick. 10-15 trips in the car since then and it hasn't tried to make a phantom call again. Here's hoping that my streak continues....
Pantoot
81
36
Arizona
Same problem with 10.2 beta 1 and 2. Just got beta 3, hopefully this fixes it.
f-stop
1,460
1,403
Vancouver BC, Canada
strange... I just had this same problem this morning for the first time ever. Up to now (car is 1yr old) I've had zero problems with Bluetooth, whether receiving calls, bluetooth music, or syncing/displaying the calendar each morning.
The car's last firmware update was back on Oct 31 (2.42.40), and my iPhone (7+) hasn't had its software updated for 3 or 4 weeks, so nothing has changed in that timeframe, then suddenly today this issue.
flipb
81
58
Annandale, VA
Forgive the thread hijack, but I'm having a different iPhone/Bluetooth issue and didn't want to start a separate thread.
I have no trouble with my iPhone connecting via BT, and I sometimes stream media from the iPhone without trouble. However, the first time (per drive) that I get an incoming call, I answer via the touchscreen, and cannot hear the other party at all. I've confirmed each time that my iPhone is outputting the call to the car via Bluetooth. Typically, the other party hangs up within a few seconds - I'm not sure whether they hear me saying "Hello? I can't hear you!" or if they hear nothing.
Then, if they call me back, or if I call them back, BT works fine. It seems to happen only on the first incoming call of any given drive.
Anybody had a similar experience? Recommendations?
donv
599
47
Lake Jeanclia, OR
I have this exact problem with my iPhone 5S. While I think it's an iPhone problem, I have to admit that it doesn't do it in any of my other bluetooth equipped cars.
f-stop
1,460
1,403
Shut off the "Hey Siri" option. With Hey siri the phone is constantly listening hence why it thinks it's on a call. This fixed all the issues for me.
sounds like this may be the likely culprit, good call. I mentioned a few posts above that I've had this problem exactly once (though not again since then), but a while before I had the problem I actually was trying something with "hey Siri" turned on - something that I'm not normally using but was that day. Turned it off just now, hopefully solved.
donv
599
47
Lake Jeanclia, OR
I tried making a call using the car's phone UI, and after hesitating for a few seconds, that seemed to fix it. At least for the rest of the day. We'll see what happens tomorrow.
Lmredcar
New Member
May 21, 2017
2
0
Saratoga CA
I also have been having problems with my iPhone 7 since I got it. I have my hey Siri turned off and everything is updated.
I will make a phone call from the car everything fine. One of next phone calls I make hands free they can't hear me even though iohone shows Tesla. I then need to put it on speaker this also includes incoming calls
It is very intermittent and very annoying
I will call service and try dialing from console
David.85D
1,348
1,120
My issue went away when I upgraded my phone from 6 to 7. Both had the most recent version of iOS. Left me wondering if something wasn't wrong with the Bluetooth on the iPhone. If you have access to another iPhone 7, I would try it and see if you have the same problem
eschummer
105
85
San Francisco, CA
I've experienced similar problems intermittently on my year-old S90D. I currently drive an older loaner S85 and no problems so far. Not sure what gives..I have an iPhone 7 plus - latest iOS...
vthomas
37
28
@flipb - I have this exact issue. Did you ever figure out the cause?
