Bluetooth issues Model S and iOS 8.4
Discussion in 'Model S: User Interface' started by andrewket, Jul 4, 2015.
  1. andrewket
    andrewket Well-Known Member
    I'm experiencing new Bluetooth issues since upgrading my iPhone 6+ to 8.4. Bluetooth occasionally disconnects and then re-connects within a few seconds. It's enough to move a call back to the phone or to drop streaming music. Anyone else seeing this?
    I just tried repairing to see if that helps. My watch is also occasionally dropping so I think it's the phone.
  2. stevem
    stevem Member
    NJ USA
    I have 8.4 on my iphone 6 and I don't notice any issues like that. Sorry.
  3. RLA12194
    RLA12194 Member
    Houston, Texas
    I've noticed spotty Bluetooth performance too since upgrading to the Samsung Galaxy S6. Granted, it's the android platform and different than the OP, but it is noticeably less reliable than what it was with my S4.
  4. AnOutsider
    AnOutsider S532 # XS27
    My phone tricked me into updating to 8.4 earlier (I could've sworn I clicked no!), but BT has always been spotty at times, so it wouldn't be anything new, sadly.
  5. travwill
    travwill Active Member
    Chicago, IL
    No issues here on 8.4. You have an older iPhone?
  6. rickgt
    rickgt Enthusiast owner/member
    Carmel
    using a 6+ with iOS 8.4 and have no issues (other than the usual stuff that has been around a while: phone not connected, touch connect, voila it works fine) with 6.2 2.4.149 on my car.
  7. andrewket
    BT has been relatively stable for me for awhile now. This is a new problem on 8.4. I'll try to capture a video of it.
  8. jomo25
    jomo25 Active Member
    Scottsdale, AZ
    No (new) issues with BT on my iPhone 6 with iOS 8.4. The only issue continues to be the same issue I've had forever: All's good until I access Facebook on my iPhone. For some reason, the Facebook app just causes continuous disconnects. No other app has issues that I've found (not even Instagram). Just Facebook. On my iPhone 6 and my wife's iPhone 6. Weird.
  9. andrewket
    Interesting. I started using apple music. Maybe it's the app and not 8.4.
  10. jshear
    jshear Member
    Toronto Canada
    I have the same issue with Apple music and blue tooth.
    Jeff
  11. jomo25
    Scottsdale, AZ
    Using Apple Music extensively. No BT issues with it whatsoever.
    Firmware: 6.2 (2.4.249)
  12. lg_golfs
    lg_golfs Member
    Southern California
    I had this issue. It would drop after 5 seconds. Turned out it was my Tile. Do you have other items that use Bluetooth as well? If so, unpair them to see if that might be the problem.
  13. andrewket
    I actually have two tiles that are frequently in the car with me. I'll experiment with that. However, I've had them for months. Maybe it's a combination.
  14. ABVA
    ABVA Member
    Northern Virginia
    After upgrading my iPhone 6+ to ios 8.4, every morning phone will not automatically reconnect. Car displays "phone not connected". Once phone is powered off and restarted it connects. Not a major issue just little annoying. Any suggestions or help appreciated.
  15. jhs_7645
    jhs_7645 VIN: #3305
    Camas, WA
    Spot on, it’s the tile app, not the tiles. I had this issue and even worked with the tile app folks. They had no solution other than to kill the Tile app every time I get in my car. That was months ago and they do not have a fix. Needless to say, that made tile almost useless to me.
  16. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    I'm seeing same thing on 8.4. Will disconnect for a few seconds then reconnect. You have to manually select your phone again in the list to get it to play.
  17. smilepak
    smilepak Active Member
    Eastvale, CA
    Just got Tess, paired and music all played great with iOS 8.4
  18. AmpedRealtor
    AmpedRealtor Well-Known Member
    Buckeye, AZ
    What is a "tile app"? Are you guys do-it-yourselfers? lol
  19. JPP
    JPP Active Member
    SF Bay Area, CA
  20. Daeke
    Daeke Member
    Austin, TX
    Is your watch a Pebble, by any chance? Mine does the same thing, but if I disconnect my watch the car's BT connection works fine.
