Bluetooth Music
Discussion in 'Model 3: User Interface' started by Dante, Jun 30, 2018.
  1. Dante
    Dante Member
    Canada
    So I'm a bit surprised that there isn't another thread about this (or I can't seem to find it). Got my Model 3 a few days ago, and was surprised at how poor the sound quality was. I read people ranting and raving at how "premium" the premium sound system was, but I had to crank the volume to max, and my music still sounded quiet, faded, and all around crappy. 3/4 of the way through my drive home, I figure I'll try out the included streaming services, and WOW. Huge difference. Completely understand the ranting and raving. But my question is: why does my music coming from my phone (iPhone) sound terrible? My other car is a Mazda 3, and the music played through bluetooth sounds basically the same as the music coming from the USB plug into the iPhone. (The bluetooth call quality sounds horrible though on the Mazda, whereas it sounds great - minus the echo - on the Model 3).
    My questions:
    Is there a way to play your own music through your phone that won't make it sound like *sugar*? I've gathered from reading around that you can't use the USB plug to play your music (correct me if I'm wrong!). The only workaround I have read is to make a USB stick and plug that into one of the front ports? But it's also limited in what audio files you can use?
    Will a software update make the bluetooth audio quality better? (Or heck, is there something wrong with my car that's making the bluetooth music sound so bad? How has nobody else complained about this?)
  2. hacer
    hacer Member
    Clarksville, MD
    My wife does this all the time with her iPhone, it sounds great (and very loud without full volume). Is it possible that your phone's volume (or source volume) affects the bluetooth stream and it is set near zero?
    • Helpful x 2
  3. Dante
    Dante Member
    Canada
    Thanks for the suggestion, I will give it a try today! I just assumed it was a car issue, maybe it's just a phone issue :D
    Also, I just realized the forums auto-substitute *sugar* for something else I wrote hahahaha.
  4. Dante
    Dante Member
    Canada
    Ok, pumped up the volume on my iPhone, and played with a few of the EQ settings, and the music sounds much better now. Thanks! Was getting tired of flipping through random songs I didn't actually want to listen to on the "Radio"!
  5. Narekzo
    Narekzo Member
    Beverly Hills CA
    Have you tried using another phone to see if there's a difference?
  6. flashflooder
    flashflooder Member
    Charlotte, NC
    Most of my other cars disregard the iPhone's volume when streaming over bluetooth (acting more as a line-out to the car's audio system). For whatever reason, the Model 3 takes it into account. Luckily, iPhones will "remember" the volume setting for that device.
  7. amitmishra4
    amitmishra4 Member
    Bayonne, NJ
    Hmm every car that I’ve ever owned has taken the phone volume into regard when using Bluetooth to stream music. Not just cars, as far as I can remember, Bluetooth speakers and most other devices behave the same way. The reason I know this is the I will usually keep the Bluetooth speaker volume at the max and use my phone volume buttons to control volume at the source so I don't have to get up and walk to the speaker every time to adjust volume. Glad you figured it out though and good luck with your model 3.
  8. Fernand
    Fernand Member
    Northern california
    #8 Fernand, Mar 29, 2019
    I just did some frequency response scans in my M3's cabin using a
    calibrated mic and playing a pink noise WAV file off a USB stick.
    What I found was that the factory settings were not very flat. At all.
    That can be improved with the "tone" faders. Here's the factory default
    with the tone faders set "flat".
    It can be corrected quite a bit by setting the tone faders (from left Bass to right Treble):
    -3.0 +2.0 -1.0 0.0 0.0
    But the next question was how the playback over Bluetooth differs.
    What I found was that first of all, the level is a lot lower. That affects
    the subjective impression of quality a lot.
    But once the levels were matched, the frequency response
    was (surprisingly) not changed much, mostly a little loss in the very
    high end that few adults hear anyway, like above 16KHz.
    I didn't get into distortion measurements, that's for another day,
    but this satisfied me at least knowing that the Bluetooth isn't
    a disaster, it's probably viable for most listeners, once the level
    is brought up on the phone.
    Yes, on this bluetooth scan I forgot to bring the 2nd bass fader up to the same +2.0 level,
    once I did the USB and Bluetooth scans looked even more alike.
