The BT module is one of three in a chain that connects to the back of the in-dash unit. I started having troubles with mine, with it "playing" but with no audio was getting through. With the help of the SC and a local car audio store eventually determined that the Sirius module, which was upstream from the BT module, was failing, and interrupting the audio chain. Since all but the iPod unit have a daisy-chain in and out, I re-connected the chain to put the BT module first, then the satellite unit, then the iPod. The satellite system still wakes up once in a while (I do not have a subscription), but the BT works reliably now either way. No clue (or care) if the iPod dock has ever worked, as I don't have anything to hook into it.
So, you might check to see what order your modules are strung together, and if the BT module isn't first, it's not too difficult to re-connect them so that it is. I did it myself by gently removing the left-hand panels where the trunk release and headlight switch are located. The modules are in a well inside the car's frame which is accessible from there.
