the car "pairs" with you phone just like a set of wireless headphones. bluetooth should automatically disconnect when the car is out of bluetooth range, like 30 something feet. isn't that how it knows you've walked away so it can lock?
when you go inside your house, your phone might still be too close to the car, within bluetooth signal range.
Range is theoretically >100m for BLE, and 100m for Bluetooth Classic, assuming clear line of sight. I have seen the app report being connected (which presumably just refers to BLE phone-as-key connection) from at least 100 ft. away. Bluetooth has a (not entirely accurate) mechanism for determining how far away a device (phone) is from the host (car). From my limited testing, it looks like the lock/unlock works from about 10 ft. away (YFMV). Not sure how close phone has to be for call audio will transfer to car.
Ideally, the car should know the phone is inside and only take over calls if so. The car could also warn you (with a honk) if you leave your phone in it, get out and close the driver's door. I'm pretty sure there are enough Bluetooth antennas to allow this to work via triangulation, but maybe they found that it isn't accurate enough. Or it could just be waiting to get to the top of the priority list.
BTW, people assume that the phone as key uses BLE, but I haven't seen that officially confirmed by Tesla, and it's not explicitly stated in the manual. It probably does, though.
