BMS Failure?
Discussion in 'Model 3' started by afawcett, Mar 2, 2021 at 9:22 PM.
  1. afawcett
    afawcett Member
    San Diego
    I’ve had my mid range Model 3 for 2 years and 1 day. Today I was driving to get dinner, and I was stopped at a red light. The light turned green, and my car made it about 10 feet before it started lurching band making a loud clunking noise. I got out of the intersection and pulled over to the right side of the road immediately.
    I got not one, but 3 error messages. I rebooted the car while calling Tesla for roadside assistance. I told them I rebooted the car and they had me do it again anyways. When that didn’t clear the error, they sent out a tow truck. Dispatch called me and the were very unorganized, they ended up calling me back about 5 times getting the same information.
    While I was waiting for the tow, I continued to troubleshoot my car. I couldn’t even shift into neutral, and the first time I put it into tow mode nothing happened. I kept fiddling with it and eventually got tow mode to kick in (verified by rolling my car).
    The exterior and interior lights worked, touch screen worked, windows worked and the sound system mostly worked. Connectivity to my phone was real spotty, and normal the Bluetooth connection is rock solid. As for what didn’t work - climate control, seat heaters, and couldn’t shift out of park - drive, reverse or neutral.
    This made me think the 12v system was still running but the high voltage system was down. I checked my wheels and underneath my car and there was no signs of damages. Dropped my car off at the service center, so hopefully they will figure it out tomorrow.
    Has this happened to anyone before?
    • Informative x 2
  2. brkaus
    brkaus Well-Known Member
    Austin, TX
    Sounds like the DC2DC converter or contactors. But the clunking noise and lurching... not sure.
  3. Phlier
    Phlier Bluebird
    Utah
    Agreed.
    Could be a cascade failure... An inverter failure may have caused the DC to DC converter to fail. A failing inverter could definitely cause lurching, although depending on failure mode, a failing DC to DC converter could do it, too.
    Really sorry this happened to you, @afawcett , let us know what happens?
  4. KenC
    KenC Active Member
    Maine
    Well, keep us informed, would be useful to know what the problem is.
  5. afawcett
    afawcett Member
    San Diego
    I got my car back today! Telsa said the rear drive unit inverter failed, which blew the pyro fuse and led to the 12V battery failing.
    I’ve heard of inverters failing, but in both cases the car wasn’t moving.
    Additionally, because the car did not have power, Tesla needed to “break in” which damaged the weather seal which they also replaced.”
    • Informative x 4
