Musk's assessments of battery cells were confirmed by Donald Sadoway, a professor of electrical engineering at the Massachusetts Institute of Technology.
"I would have used the same words," says Sadoway. "I would have used the same words. I'm glad someone with such a big reputation put it on the line."
"He's engineered [Tesla's battery] to prevent the domino effect, while Boeing evidently doesn't have that engineering," adds Sadoway.
I wonder if Musk would be interested in Tesla building battery packs for Boeing. That would be a pretty big name to tack on the "supplied by Tesla" list. And it would tell an interesting story of cross-industry technology wins, etc.
"Large cells without enough space between them to isolate against the cell-to-cell thermal domino effect means it is simply a matter of time before there are more incidents of this nature,"
Elon Musk: Boeing 787 battery fundamentally unsafe
(And then JRP3 post a video of "better design" from company under chapter eleven ;P )
Boeing has declined help from SpaceX and Tesla from the article above. Doesn't seem like a smart move even from a purely PR perspective. They should be seen as taking every possible route to fix the problem. And for a multi-billion dollar plane, throwing a few million dollars at SpaceX to bail them out might get the planes back in the air faster and help their share price.
I wonder if their rejection has more to do with the fact that Boeing and SpaceX are basically competitors in the race for space. If they're seen as inferior to Tesla by accepting their help, it could be more likely that Tesla will be awarded contracts over Boeing.
Space between cells is necessary if using a chemistry that runs hot and is more prone to thermal runaway.
To be fair to Mike, the external battery box did do its job in containing the fire. I think it's still too early to blame the battery pack design (or the cells themselves) until the investigation actually finds a cause for the failures.From the same article where Elon "calls it like he sees it" (Elon Musk: Boeing 787 battery fundamentally unsafe)
Mike Sinnett, Boeing's 787 chief project engineer, explained the careful design philosophy employed for the 787's battery system, the first to serve as a starter for an auxiliary power unit and emergency power back-up in a commercial aircraft.
"I design a cell to not fail and then assume it will and the ask the next 'what-if' questions," Sinnett said. "And then I design the batteries that if there is a failure of one cell it won't propagate to another. And then I assume that I am wrong and that it will propagate to antoher and then I design the enclosure and the redundancy of the equipment to assume that all the cells are involved and the airplane needs to be able to play through that."
Well, good luck with that Mike :tongue:
