tfinan
I timed the message this morning. It took 16 seconds after first depressing the brake pedal for the message to clear.
Maybe there is a bug in the latest firmware?
I turned off energy saving and always connected and the screen comes on very quickly now.
I used to have to reboot the MCU to get it working, especially if the car has been sitting for a few days, now no necessary.When you say the screen comes on quickly do you mean after you reboot the MCU or you don't have to reboot the MCU? That's my issue is that my MCU doesn't come back on unless it's rebooted. The one time it actually functioned properly in my mind was the evening at the movies whenever it said it needed to power back up and only took 10 seconds. But again the screen came up on it's own without a reboot at that time. Again that instance I believe the car functioned exactly how it was designed. When the MCU doesn't come back up without a reboot is the problem for me. I've recently found out if the MCU has stopped functioning properly it will not control what it normally does like, HVAC, music, and charging which is biggest issue of them all for me. The Service Center responded to my e-mail and stated they would look into my past requests for service and see if they can try and figure out what's going on. Some other owners I've spoken with who I've known for a while mentioned it's probably some memory issue with the MCU and it might be going bad. The same group of people also showed me their trip meters and one guy's car had 94,000 miles on his trip meter. Hasn't reset it once since purchasing so I feel the whole 'need to reset the trip meters once every couple weeks' is something that they tell people because it probably helps in the short term but doesn't actually fix the memory issue.
Ohh boy! Report back and let us know what the issue is!My car died today and needed to be towed to service center.
First problem I noticed was airbag light. I powered off car and then received the following alerts. The car would not shift into drive or reverse. View attachment 369719
Wow! How old and miles on it? I guess your talking me into extended warranty!They ended up replacing our MCU. I didn't get a great reason as to what was causing our issue. They did mention that they were unable to see any logs whenever it went down and when it came back up they couldn't see any information regarding what was happening during the time frame in question. My advice is document everything and get as many photos/time stamps as to when you're having issues. We'll see how it handles for the next few months to see how it does.
