Bosch wiper blades
Discussion in 'The UK and Ireland' started by Afdyce, Mar 7, 2015.
  1. Afdyce
    Afdyce Member
    Hampshire, United Kingdom
    If anyone else out there has found the factory wipers both noisy and prone to leaving an uncleared streak half way up the driver's side, this is the answer:
    Driver's side: Bosch Aerotwin AP28U
    Passenger side: Bosch Aerotwin AP18U
    They are easy to fit, just put the wipers in to "service mode" first and protect the screen with a cloth while you have the old wiper off.
  2. smac
    smac Active Member
    Nottinghamshire
    Are these what Tesla now put on at service (inspection) time ?
    I heard a rumour they'd acknowledged how rubbish the original blades were, and switched to Bosch for the newer cars and service replacements. I'm still a five months away from needing a service and finding out :D
  3. KingKitega
    KingKitega Member
    Hong Kong
    Mine were replaced by Bosch ones last week. The loaner I had was also fitted with Bosch ones too. They charge £59 to replace so better getting them online.
  4. mgboyes
    mgboyes Member
    United Kingdom
    Yes they're supplying them new from the factory with Bosch wipers these days (for all markets I believe) following feedback from the UK.
    On Amazon or similar you should be able to get the pair for no more than £30.
  5. smac
    smac Active Member
    Nottinghamshire
    Service centre just replaced mine. They are sooo much better.
  6. Alan
    Alan Member
    UK
    Funny, it was the same with my Roadster 5 years ago - replaced the standard ones with Bosch ones and it was a huge improvement. Did the same on my Model S and another great improvement - guess it does not rain in California so they have no experience with which wipers are best :)
  7. Nhawk
    Nhawk Member
    NJ
    One issue I noticed is that the alternate wipers are a bit shorter for the driver side at least vs the originals (made in Belgium). The Bosch are listed as 650mm, which comes to 25.6" overall, while the originals were 26" overall with ~25.6 rubber wiper.
    The reason I ask, is that I tried the Valeo 26", but since they're also 650mm overall, their rubber wiper portion is only ~25" and thus they're almost an inch shorter (mostly on the bottom when wiping)
    Can someone who has the Bosch, please measure the length of the wiping edge?
